Fork-Style Pie Crust Edging
Forum topic by TriedIt posted 05-24-2020 11:47 PM 245 views 0 times favorited 2 replies Add to Favorites Watch
View TriedIt's profile
TriedIt
1 post in 41 days
05-24-2020 11:47 PM
Not sure what to call what I’m looking for, but I saw it referred to as pie crust edging.
https://s3.amazonaws.com/vs-lumberjocks.com/qav033e.jpg!
I bought a mirror and will make a matching console I’d like to do the same design on the wood.
What is this technique/style called and what tool do I use to etch lines in a 1” strip of wood? A grinder? I haven’t seen the thin, inch+ long attachment.
See pic of mirror (plastic painted over).
I case poc doesn’t come thru, mirror is here: https://www.kirklands.com/product/Mirrors/Decorative-Mirrors/Large-Silver-Luxe-Leaner-Mirror-372x672-in/pc/2450/c/3056/210032.uts
2 replies so far
View CaptainKlutz's profile
CaptainKlutz
3164 posts in 2265 days
#1 posted 05-25-2020 08:55 AM
Those look like they were stamped in to the metal strip. Can’t stamp wood easily. lol
What is spacing between grooves?
Sort of looks like miniature Dentil Molding insert profile (Example 1, Example 2) except in wood they have square edges.
With round over edges it would be ‘elegant’ Dentil molding.
Could make similar sytle cuts with plunge round over bit in router.
Very tedious work by hand, easy for CNC.
Would cut grooves in wide board, cut into narrow strips then add the side roundover.
Amana has point cutting round over bits, or Plunge round over bits with wider line between the round over.
Whiteside has various plunge panel bits also.
These style bits tend to get used in CNC tools, and will find similar plunge bits in various CNC tooling catalogs.
If sharp edges are acceptable, could buy/make a cross lap jig for TS?
Best Luck.
View Nubsnstubs's profile
Nubsnstubs
1723 posts in 2500 days
#2 posted 05-25-2020 02:13 PM
That detail looks like a 1/4” flat between each round over. 18 years ago, I had a bit made with a 5/16” flat that looks just like those in both plunge panel bits links above. that’s going to be your best bet. Be sure to route the length first, then cross route the detail. ............ Jerry (in Tucson)
