My 17 inch 2 hp Grizzly with steel wheels is making noises?
Forum topic by DocSavage45 posted 05-23-2020 01:42 AM 784 views 0 times favorited 24 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8932 posts in 3573 days
05-23-2020 01:42 AM
Topic tags/keywords: question bandsaw
Hey LJ’s,
I’m back with another head scratcher for me
Bought a 17 inch Grizzly Bandsaw 2 HP with steel wheels instead of aluminum two years ago. I replaced my GO555 as I needed more HP for ripping logs and making veneers.
Needing to cleanup my spaulting/rotting logs and decided to put the 3/4 blade on the machine.
After adjusting all the guides and cleaning the wheels I put the big blade on. Significant rubbing metal noise. Checked everywhere to localize the sound. Removed the blade and ran the motor without…no noise.
Put a 1/2 inch blade on and the noise was less???
Varied blade tension and less tension…less noise.
I’m guessing my problem is in the pulley or bearings?
An inquiring mind needs some direction?
Thanks for helping!
-- Cau Haus Designs, Thomas J. Tieffenbacher
24 replies so far
118047 posts in 4308 days
#1 posted 05-23-2020 01:56 AM
Hi Tom
I agree with you,I think the 1st suspect would be bearings. Do you take pressure off the blade when not in use?
DocSavage45
#2 posted 05-23-2020 01:58 AM
Most of the time Jim. Have reminders up that I don’t see.
View EllenWoodHead's profile
EllenWoodHead
83 posts in 107 days
#3 posted 05-23-2020 02:37 AM
Does it have the ball-bearing style blade guides? They make a lot of noise when they’re worn.
-- "wood" and "good" rhyme, but not "food"
View doubleDD's profile
doubleDD
9356 posts in 2774 days
#4 posted 05-23-2020 02:44 AM
Loosen all the bandsaw guide bearings so nothing is touching the blade. Try that. As Ellen said bearings going bad will make a lot of noise.
View Greg the Cajun Wood Artist's profile
512 posts in 1673 days
#5 posted 05-23-2020 03:05 AM
Have you closely checked the areas of the blade guard where the blades exits the housing of the top wheel.?
When I put my 3/4 blade on my bandsaw it made a similar noise as you are describing. I needed to do a bit of adjusting from the blade guard from where it was set for a 1/2” blade.
A 3/4 resaw blade requires greater tension and after adjusting the blade guard I spin the wheel by hand to locate any metal-on metal noises.
This solved the noise problem for my bandsaw with the wider blade. Mine is a 14” Powermatic with a riser block for increases capacity..
-- Wood for projects is like a good Fart..."better when you cut it yourself" Don't take yourself so seriously. No one else does
View Aj2's profile
Aj2
2949 posts in 2529 days
#6 posted 05-23-2020 03:08 AM
Does it have a foot brake.
My saw has a foot brake and it will make a scraping noise debris get stuck somewhere.
Good Luck
-- Aj
View therealSteveN's profile
therealSteveN
5545 posts in 1305 days
#7 posted 05-23-2020 03:13 AM
Thinking of it was a bearing it would have walked in squealing, just quieter, as time went along they up the volume, figuring they didn’t get your attention.
If it happened all at once, I’d check the complete path, but especially around the guides for a sliver of wood. Or just wait till the blade makes it a small enough sliver to fall out on it’s own.
-- Think safe, be safe
DocSavage45
#8 posted 05-23-2020 03:49 AM
Ellen, Noise is in lower part of saw, but it might be worth checking.
DocSavage45
#9 posted 05-23-2020 03:50 AM
Dave, I went through the adjusting , Might have missed something?
DocSavage45
#10 posted 05-23-2020 03:54 AM
Greg,
Did it with the 1/2 inch blade as I put the 1/2 inch back on. Adjusted tension from lighter to heavier. Will look for subtleties. Hoping it’s not the bearings.
DocSavage45
#11 posted 05-23-2020 03:55 AM
Aj, didn’t get the foot brake, have to wait for it to slow down.
DocSavage45
#12 posted 05-23-2020 03:58 AM
therealSteveN,
no squeal, hope it’s just something I missed when I cleaned the saw and set up the blades.
View MrUnix's profile
MrUnix
7991 posts in 2930 days
#13 posted 05-23-2020 04:10 AM
no squeal, hope it s just something I missed when I cleaned the saw and set up the blades.
- DocSavage45
Did you buy the saw new or was it used? Even if you got it new, Grizzly is notorious for shipping tools with cheap ass bearings that can fail rather quick – I’ve seen them go bad in under a year on some machines. Keep in mind, bearing failure does not always produce a squeal – there are many ways they can fail. But you need to isolate the noise first, so do the suggested troubleshooting stuff mentioned and figure out where it’s coming from. Just replacing stuff hoping it fixes the problem is not the way do it!
If it does turn out to be a bearing – replace ALL of them. If one is failing, the others will not be too far behind.
DocSavage45
#14 posted 05-23-2020 05:35 AM
Brad,
I like my 14 inch go555 better Was pristine when I sold it. The guy walked in turned it on and bought it. LOL!
This saw was new. It has more power and cuts better. Ive owned it for a couple years. I’ve heard the bearings on the Grizz are not the best, but????
Step by step and trouble shoot.
View CaptainKlutz's profile
CaptainKlutz
2993 posts in 2225 days
#15 posted 05-23-2020 11:59 AM
Bought a used Grizzly 17” BS last year with aluminum wheels. Used it couple times and it started making noise and needed bearings. Machine was only 7 years old, bearings failed a bit early for light use tool? Found cheap Chinese bearings inside everything, including motor.
The wheel bearings are super easy to change. One bolt removes the wheel. Pulls off with sharp tug. Snap rings retain the bearings and once removed, used large metric socket on bench to push them out. Did not need a bearing press. Installation was just as easy. To make it easier, place the bearings in freezer for couple hours before assembly. Grease them up, and they drop right in finger pressure. Uses a standard size sealed bearing.
Had to use bearing puller to remove the motor bearings. It took me longer to remove/install motor, then it did to swap the bearings. Used 1” PVC pipe to drive the bearings onto shaft.
easy peasy lemon squeezy
YMMV.
