Forum topic by controlfreak | posted 05-21-2020 05:11 PM | 523 views | 0 times favorited | 11 replies | ![]() |
Topic tags/keywords: question joining The double screw thing is what the hardware store gave her to use so lets not waste time on that thingy. Background: I haven’t seen the setup but I think this is to fill a gap between two cabinets. The gap is not very great and was the result of not wanting to relocate a heat vent in the wall. The desire is to have a granite top with these legs which need an extension to get to the right height. Not having a way to attach the leg to the top is one problem. the other is how to keep the legs from racking when the table is moved. Some random thoughts that come to mind: I could add the extension via some dowels. Then add some rails and do a mortise that spans both pieces. Then place a secondary apron around the added extensions just to mask the joint and possibly add some more rigidity. I suppose I could also some sort of morticed rail at the bottom to hold that end of the legs assuming that it won’t interfere with the storage. Come to think of it I could add a shelf to do the same. Any ideas would be welcome. |
11 replies so far
#1 posted 05-22-2020 01:31 AM |
One way to do this is to drill oversized holes into both ends that are to be joined. By oversize, I mean bigger than the dowel you will use. Mix up a thick batch of epoxy, using an appropriate thickener. You’ll need enough to completely fill the voids around the dowel, and should get some squeeze out. When the epoxy is cured, of course you have to clean everything up. The reason for the oversized hole is that it is almost impossible to drill perfectly centered, perfectly aligned holes into end grain. This is an excellent quick way to repair broken chair legs and spindles. But making the joint strong enough to resist racking forces is problematic. By the way, I harbor a deep antipathy to the dowel screws your are contemplating. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#2 posted 05-22-2020 10:40 AM |
Thank You for the epoxy idea. I was contemplating using dowels and glue. What is a dowel screw? |
#3 posted 05-22-2020 08:31 PM |
That’s a dowel screw sitting on the leg in your photo. They have a lag screw thread on each end. You join the pieces by rotating one against the other, as there is no other way to turn the screw. It isn’t hard to imagine how awkward this can get as the two pieces of the assembly approach closely to each other before making contact. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#4 posted 05-22-2020 08:55 PM |
Ah, that was something my friend got from the hardware store. I already know in my heart that it would not prvide enough strengh to join the pieces. |
#5 posted 05-22-2020 09:04 PM |
Just my Opinion Yeah it would, I’ve used them plenty of times. But, if you don’t like them, NP, not everybody does. |
#6 posted 05-22-2020 09:09 PM |
Might be easier and better in the long run to turn a new leg or otherwise start from scratch. I can’t see anyone being happy with the end result of a patched leg (structurally or aesthetically). Good luck. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#7 posted 06-08-2020 08:12 AM |
I’ve extended legs before, and I have to agree that the best solution is to turn a new leg. Even using dowels and lag bolts to join them is not as strong as a new leg IMO. |
#8 posted 06-08-2020 02:20 PM |
Rather than trying to line up the extension piece, I’d cut it oversize, glue it on with a dowel, and trim it flush with the sides of the existing leg piece. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#9 posted 06-08-2020 03:15 PM |
I was thinking of epoxy and dowling the extensions and plane to size. Then mortice some rails spanning both and possibly use some dowels to lock the rails then either fill and paint or use some sort of skirt that will mount on the outside just low enough to cover the extensions. I would need to play around to see how this will visually impact the piece. I know this may be a lot of work but it would be a skill builder for me as I have never done this type of joint before. I had to put this on hold due to not wanting to risk exposure to Covid prior to my daughters wedding this Saturday. But will still welcome any comment or suggestions to my possible plan. |
#10 posted 06-08-2020 04:16 PM |
I would probably use a lap or bridle joint, but only if I was painting. If you’re planning on a stained/clear finish, get new legs. It will be less effort than getting an acceptable match. |
#11 posted 06-08-2020 05:10 PM |
Just this weekend I extended legs on two side tables. The new bed mattress was @7 inches taller than the previous. The result was a bed side table that was too short. |
Forum | Topics |
Woodworking Skill Share
13201 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6348 |
7910 |
32773 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7278 |
1633 |
Focus on the Workspace
2635 |
1272 |
Woodworking Trade & Swap
5418 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
