Forum topic by Walker | posted 05-10-2020 09:26 PM | 415 views | 0 times favorited | 5 replies | ![]() |
TL;DR: What’s the best way to route mdf with HPL on both sides? Smaller bit or larger bit? Lower speed or higher speed? Would like to avoid chip out as much as possible. The details: I just picked up this Rockler router table and porter cable 890 on craigslist for $200. The router is in great condition, tho it’s missing the sub-base and collet wrenches. Easy enough to buy online. Came with a 15-piece bit set, which I’ll probably sell as they’re mostly duplicates to me. The table is in good shape too, it’s just missing the leveling feet. The seller said he got the set up from his dad 5 years ago, and has used it once since. To complete the brag, yesterday on ebay I scored a Woodpeckers PRL-V2-414 lift, new/open box for $210. I know it’s for the Milwauke 5625, but for that price I figured I can have my choice of routers, and buy the appropriate adapter from Woodpeckers for $32. My intention was to build an extension wing/cabinet for my Delta 36-725T2 table saw. I figured the rockler table is a good start. I can use the fence, feather boards, and miter track. Build a cabinet around the steel legs and add casters. I also really like that the switch came with it. The table top is mdf with laminate on top and bottom. It will need to be cut down a few inches to fit in between the rails on the table saw. The opening for the plate will have to be expanded to fit the Woodpecker’s lift. What’s the best way to do that while avoiding chipping out the HPL? What size bit and speed is best? As a side note, should I keep the PC890 for table use or should I sell it and wait for a 3hp router? -- ~Walker |
