Incra 5000 miter sled setup
Forum topic by BB1 posted 05-09-2020 08:22 PM 773 views 0 times favorited 17 replies Add to Favorites Watch
View BB1's profile
BB1
1689 posts in 1735 days
05-09-2020 08:22 PM
So I splurged and got myself one of the Incra 5000 miter sleds (anniversary gift from my amazing husband).
I am started on going through the instructions to get it set up for the very first time. Immediately I am feeling stupid as directions indicate it is configured for use on the left side of your blade which is where I planned to use it but then it said that would be ideal with a right hand blade tilt table saw.
I have a Powermatic 1000 which is a left tilt – at least how I am defining the tilt
So my question is do I really need to reverse this to use on the right side of the blade (directions explain how to do that). I’m guessing that this would be the configuration if doing any sort of a beveled cut so the blade would not tilt toward the miter gauge? I like having the off switch easily accessible and it is toward the left. Usually just use my leg to turn off the saw so I don’t have to reach down away from my workpiece. Just don’t want to mess this up at the very first step.
Thanks. Hoping I’m just tired and making this more complicated than it really is
17 replies so far
View bondogaposis's profile
bondogaposis
5875 posts in 3238 days
#1 posted 05-09-2020 08:36 PM
That’s the answer to your own question.
-- Bondo Gaposis
View dbw's profile
dbw
449 posts in 2524 days
#2 posted 05-09-2020 08:46 PM
I have an Incra Miter Express. My instructions say if the blade tilts to the right use the left hand miter slot. If your blade tilts to the left use the right hand miter slot. I have a SawStop cabinet saw, which is left tilting. I set up the Miter Express on the right miter slot. If you do it reverse it’s possible the blade, when tilted, will cut into the miter gauge fence. By the way Incra has an EXCELLENTLY AWESOME tech support department. If you aren’t sure of what to do call them. I’m willing to bet they will help you.
-- Measure twice, cut once. If it still doesn't fit get a big hammer.
View BB1's profile
BB1
#3 posted 05-09-2020 09:01 PM
Thanks – will make a call (guessing Saturday isn’t an option for tech support). If I have to switch, disappointed as I don’t like to be “away” from the stop button, and not looking forward to reversing everything.
I appreciate the insights. Thanks!
View dbw's profile
dbw
#4 posted 05-09-2020 09:14 PM
I don’t believe you HAVE TO reverse. It’s best to check with Incra. BTW reversing isn’t near as difficult as you think. All you have to do is “think backwards” :)
View Madmark2's profile
Madmark2
1729 posts in 1475 days
#5 posted 05-09-2020 09:15 PM
Install for left tilt/left slot. Cuts can always be flipped or reversed. The tilt impacts the clearances, not the cut options.
-- The hump with the stump and the pump!
View James E McIntyre's profile
James E McIntyre
925 posts in 2179 days
#6 posted 05-11-2020 08:11 PM
That’s a great saw BB1.
You can set it up on either side of the blade.
Although I could, I never tilt my blade when I use it. I do have the miter section on the right side of the blade because I also have a left tilting saw.
If you have questions call Incra their customer service is great.
-- James E McIntyre
View BB1's profile
BB1
#7 posted 05-12-2020 01:49 AM
Thanks. Hope to have an opportunity to contact Incra later this week Based on your comments and those of dbw, sounds like they are helpful.
Thanks to everyone for all the responses and insights.
That s a great saw BB1.
- James E McIntyre
View newwoodbutcher's profile
newwoodbutcher
817 posts in 3737 days
#8 posted 05-12-2020 03:57 AM
BB1,
I’ve been using the Incra 5000 on my grizzly 691 cabinet saw for about a year, after using and loving the Dubby Cross cut Sled for over 20 years. Mine is mounted in the left track. Works great. Seems safe. My only gripe with this sled is the lock down knobs on the fence and stop. They are small, hard to lock and unlock and finikey. I’m still experimenting with different hardware Choices. But other than that I think it’s a great sled.
-- Ken
View gmc's profile
gmc
75 posts in 3043 days
#9 posted 05-12-2020 02:08 PM
I too have a SawStop and the 5000. I mounted it on the left side of the blade. For my uses I can’t imagine a cut that I would make to cause an issue. Now if your going to be making a lot of miter cuts with angles, that might be the case for moving it over, which is very easy to do. It’s a great setup, enjoy it.
-- Gary, Central Illinois
View RichBolduc's profile
RichBolduc
1415 posts in 1004 days
#10 posted 05-12-2020 02:59 PM
I just set mine up a few weeks ago and set it up for the left tilt like they discuss. When I mentioned it in a few FB groups, they made the point that if you do and dado stacks, you’ll essentially not be able to use the sled due to where they blades stack. So you’ll need to figure out would you rather use it for bevel cuts or dado’s?
Rich
-- https://www.2dogswhiskey.com/ 10% off all products with code LJ10 https://www.facebook.com/2DogsWhiskey/ https://www.instagram.com/2dogswhiskey/
RichBolduc
#11 posted 05-12-2020 03:02 PM
One thing I am debating is adding another fence to my off-cut piece to act as an additional stop block
Rich
View BB1's profile
BB1
#12 posted 05-13-2020 02:13 AM
How easy would it be to switch back and forth between right and left? Still like the idea of being toward the left where my off switch is for standard cuts, but also anticipate wanting to use for bevel and my blade tips to the left so sled should be on the right.
Haven’t had a chance to call Incra – on my list before I finalize any decisions or really get rolling on the setup.
Thank you for the added comments. I appreciate all the LJ who continue to help me. Learning process never ends!
View AndyJ1s's profile
AndyJ1s
465 posts in 642 days
#13 posted 05-13-2020 04:50 AM
Interesting discussion.
It looks to me like whichever one you choose (bevel or dado) the fixed part of the sled would still have to be removed or re-positioned to clear the blade. For that I might buy the parts to make a separate fixed side, so I wouldn’t have to reset my normal one.
-- Andy - Arlington TX
View Andybb's profile (online now)
Andybb
2887 posts in 1491 days
#14 posted 05-13-2020 07:43 PM
- James E McIntyre
+1
-- Andy - Seattle USA
View BB1's profile
BB1
#15 posted 05-18-2020 01:59 AM
Have decided to setup on the left of the blade. Spent considerable time this weekend trying to get the guage set at 90. Trying the 5-cut method – thought I was getting close but then reset and cannot seem to get it anywhere close to correct. Trying to figure out where I’m going wrong. Was getting frustrated so just stopped, cleaned up the shop, and decided to try another day.
