Forum topic by steamngn | posted 04-30-2020 05:09 PM | 1320 views | 2 times favorited | 22 replies | ![]() |
Topic tags/keywords: riving knife table saw delta question Greetings fellow LumberJocks! I understand that there are multiple shapes/thicknesses etc….. what I am interested in are the dimensions for the “tang” portion where these knives mount. Most of the knives I’ve seen have one drilled hole and one slot to drop over a stationary pin; I am curious if this hole and slot are similar dimension-wise and if the width of the “tangs” are similar as well. so come on fellow wood butchers…. share some love… and dimensions! :-) Andy |
22 replies so far
#1 posted 04-30-2020 05:19 PM |
You need to identify which “contractor” saw. Old one with a splitter, or new one with a riving knife. Just make yourself a cardboard template. Don’t expect someone to have engineering drawings. Maybe someone can take a picture of theirs on top of some graph paper. The knife should mount flush with the left side of the blade. That way different thickness will line up with the blade as the different thickness expand to the right. |
#2 posted 04-30-2020 05:32 PM |
Oops my bad! It is an older Delta 10” saw with a splitter. I can’t read the tag that was on the original cabinet but it is similar to the 36-650. I am building the moving assembly to add a riving knife to this saw… and no I don’t expect engineering drawings. Sorry if it sounded that way! I am hoping some members will bust out the ruler and give me some dimensions. I don’t have anything as a base design to work off of and was curious if the mounting portion was similar or not. |
#3 posted 04-30-2020 06:14 PM |
Hmm? 2) Splitter mounting tab: 3) For additional education on making a riving knife, this existing thread might help you. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#4 posted 04-30-2020 07:27 PM |
Hmm? ANSWER: I am indeed making a riving knife attachment that does indeed follow the motion of the saw blade arbor. Mechanical application of the blade-arbor arc and corresponding lever are mocked up and working. 2) Splitter mounting tab: ANSWER: Since this is a completely new construction, I figured I would make the knife-mount match whatever the standard mount dimensions are – IF there is a standard, that is. 3) For additional education on making a riving knife, this existing thread might help you. ANSWER: I actually sent off a contact to Shark Guard asking this very question – I’ve not heard back, at least not yet anyway. But figured I would also throw it out here as well. I’ve seen plenty of comments/posts/attempts at adding a riving knife to older saws like this; most of them are usually tried/can’t/can’t be done… a few have been successful. None of them (that I’ve seen anyway) go into much detail about the mount itself. |
#5 posted 04-30-2020 10:27 PM |
Sorry, but the mounting tab is not standard between saws. Your new here, so here one last attempt to help: runswithscissors did one of the most comprehensive sharing of pictures, information I have seen on LJ and he was successful on a Unisaw riving knife. Even offered to sell some of them a few years ago. There is also a couple posts hidden over at OWWM with images on how folks made a riving knife for various table saws too. I don’t agree with your summary. Riving knife can be retro fitted to old saws, if you can afford the time and effort. Yes, There is very little information as tool designs are owned by OEM, and they don’t publish documents. When you get yours completed, look forward to seeing your design documents so others can copy it. Cheers! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 04-30-2020 11:15 PM |
Ok Captain, |
#7 posted 05-02-2020 10:11 PM |
Steamngn: I an very curious to see what you come up with for your riving kinife. I eventually had parts cut out to make about 15 RK kits, and assembled and sold 10 of them. My enthusiasm waned as I began to realize how much tedious hand work was involved in putting one together—welds, drilling, tapping, yada yada. I did find that the water jet technology is much better than plasma—very clean cuts, and very precise. But I still had to cut out small pieces myself. I did convert a 14” bandsaw to cut metal (with a variable pitch bi-metal blade), which helped a lot. I still use that frequently. Eventually I began to fantasize about having major parts die cast, to avoid all the welds, etc. Of course that is a very expensive process, and I chickened out. I still have parts for 5 kits, and wouldn’t mind selling the whole caboodle to someone to take it on, maybe improve and expand it. I got very little feedback from purchasers, except for one time when I sent the wrong knife thickness to someone, due to the steel shop making me up a batch of the wrong gauge They made me a new batch of the correct ones at no charge. By the way, thin kerf knives should be 14 gauge, and standard or thick kerf are 12 gauge. No need for any precise measures down to thousandths of an inch or hundredths of milimeters. I’m still using mine with good results and much satisfaction. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#8 posted 05-04-2020 01:41 PM |
runswithscissors: This worked as expected, the left vertical arm of the parallelogram tracks properly and stays vertical. So far so good!
I (usually) have access to a complete fabrication facility but due to the coronavirus issue (and having an extremely high-risk family member in the house) that ended that for the time being.
-AND THAT GOT ME THINKING: As I mentioned at the beginning of this post I have not crafted the knife mount itself just yet. I wasn’t sure if there was any commonality in mount design dimension-wise. Since that doesn’t seem to be the case I will settle on a pattern and move forward. The knife mount will have some micro-adjustment ability to set final Y-Z axis alignment of the knife with relation to the saw blade. |
#9 posted 05-04-2020 10:32 PM |
I managed to find this early image of version 2.0 (Sorry it is sideways lol) you can see the plate has slots matching the arc of the arms to allow for carrier slides. These keep the arms against the plate. The plate mounts with the angle iron to the back trunnion carrier. The plate Itself mounts to the trunnion rod. |
#10 posted 05-11-2020 06:52 PM |
steamngn really curious to see where you go with your riving knife retro fit. I am in the planning and research phase of doing the same to my unisaw. |
#11 posted 05-11-2020 07:15 PM |
The design seems interesting, but pretty complicated for what it is IMO. If you want some inspiration, check out some of the riving knife mods for a Unisaw over at the OWWM site. Here are the parts involved in one of them: Here is another similar design in action: Lots more good stuff can be found starting here: Riving knife for Unisaw Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#12 posted 05-11-2020 07:39 PM |
Thanks for sharing Brad. Quite impressive. |
#13 posted 05-11-2020 11:14 PM |
Hey Brad, I will be a little delayed in getting the metal version cut, we’re getting the store ready to reopen here in NY state…. and that is involving a ton of preparation. Stay tuned, I will keep on this as I can! |
#14 posted 05-12-2020 04:52 AM |
Just food for thought: might buy a riving knife from SawStop or Powermatic and use this as a “standard”. They are likely to sell same design for a long time and have parts available. And I know my SawStop has a riving knife and 2 different blade guard/ splitter combo devices that use the same mounting. You could for instance get a riving knife and a blade guard with vacuum port for above blade dust collection. |
#15 posted 05-12-2020 12:13 PM |
Just passing through. steamngn, is that one pic of a wooden assembly what you are building, or just a prototype? I imagine you note the one Brad posted the pic of is all metal construction. That is the path you want to follow. The repeated hammering, and mini collisions of wood being cut running into a wooden splitter/RK makes all metal the only safe, long lasting choice. -- Think safe, be safe |
Forum | Topics |
Woodworking Skill Share
13194 |
Woodturning
2812 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1892 |
Finishing
6339 |
7903 |
32747 |
CNC Woodworking
329 |
Hand Tools
6450 |
Jigs & Fixtures
1804 |
Wood & Lumber
7275 |
1632 |
Focus on the Workspace
2630 |
1272 |
Woodworking Trade & Swap
5412 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9656 |
