Need to troubleshoot Makita Mitersaw -1430
Forum topic by blueridge posted 04-28-2020 05:12 PM 225 views 0 times favorited 3 replies Add to Favorites Watch
View blueridge's profile
blueridge
28 posts in 897 days
04-28-2020 05:12 PM
I have a second hand Makita 1430 – 14” miter saw , it is missing a safety cover over the blade and also when you take your finger off the trigger it takes a long time to stop spinning. I tried changing the brushes but there was no improvement. Do I need to change out this part? https://www.ebay.com/itm/Makita-526006-5-5260065-Field-For-LS1020-LS1400-LS1430-2401B-Miter-Saw/271268778413?epid=1903923600&hash=item3f28e111ad:g:kOkAAOxyUSFSIlu6
3 replies so far
View hkmiller's profile
hkmiller
236 posts in 891 days
#1 posted 04-28-2020 06:23 PM
That looks like their motor magnet with the windings I doubt that’s your problem if that was your problem this all wouldn’t work at all
-- always something
blueridge
#2 posted 05-03-2020 03:19 PM
Ok so maybe its the armature then?
View BurlyBob's profile
BurlyBob
7725 posts in 3075 days
#3 posted 05-03-2020 06:19 PM
I’ve got the first Gen Makita 12” CSMS. Like your the blade keeps turning for quite a while after the trigger is released.
I wish this thing would give up the ghost so I could justify a new Bosch. I have to use a Wixey protractor to set all the angles as the stops are ridiculously sloppy. Also there’s no for anything close to saw extraction. I’ve had this thing since ‘97.
