Tablesaw insert under sled?
Forum topic by Pizzadave posted 04-25-2020 12:38 AM 535 views 0 times favorited 14 replies Add to Favorites Watch
View Pizzadave's profile
Pizzadave
125 posts in 1004 days
04-25-2020 12:38 AM
Topic tags/keywords: tablesaw crosscutsled insert
Hey there everyone! I have built and been using crosscut sleds for my tablesaws. Are there any disadvantages to removing the insert on my saw? I have built sleds that have replaceable inserts for various applications. I have either misplaced or lost the factory insert for my one of my saws and was wondering if it was necessary to buy a new one or make one. Thanks.
-- Dave, NY, It works-It really does!
14 replies so far
View Madmark2's profile
Madmark2
1836 posts in 1511 days
#1 posted 04-25-2020 12:57 AM
As long as you’re using the sled the insert matters not.
-- The hump with the stump and the pump!
Pizzadave
#2 posted 04-25-2020 01:22 AM
That is good to know. Thanks for your response.
View Kelly's profile
Kelly
3175 posts in 3867 days
#3 posted 04-25-2020 03:55 AM
Done
Nothing more to be said.
View pintodeluxe's profile
pintodeluxe
6240 posts in 3736 days
#4 posted 04-25-2020 05:06 AM
You should never run the saw without the insert, sled or not. It will intermittently open up the throat and expose too much blade for safety.
Replace the insert or make one. That’s the only reasonable and safe conclusion.
Pizzadave
#5 posted 04-25-2020 05:13 AM
Well now there is another angle. I appreciate your response and will take heed. Thank you!!!
View Rich's profile
Rich
6179 posts in 1512 days
#6 posted 04-25-2020 05:17 AM
Replace the insert or make one. That s the only reasonable and safe conclusion.
- pintodeluxe
I never use my saw without the insert, sled or not. But I can’t think of a reason why the OP’s question is out of line. Do you know something I don’t?
View tvrgeek's profile
tvrgeek
1055 posts in 2572 days
#7 posted 04-25-2020 10:32 AM
I never run without one. Too easy for something to get dropped or snagged. Everyone has made a stack of ZCIs right? Some with splitter for thin blade, some with splitter for thick blade, one with none, several for dado stacks…
View Lazyman's profile
Lazyman
5991 posts in 2310 days
#8 posted 04-25-2020 12:57 PM
I would simply want an insert just to avoid having something drop down inside.
Pizzadave
#9 posted 04-25-2020 03:17 PM
Safety first. I went ahead and made one up. I now have a dedicated dado Tablesaw with a sled and insert. This also allows me to use the saw making wide kerf cuts with other applications. Thank you for all the responses. I’m always learning.
View clagwell's profile
clagwell
325 posts in 715 days
#10 posted 04-25-2020 04:24 PM
Yes, it certainly doesn’t hurt to use the insert, and it probably provides a small increment in safety.
For some perspective though, consider the size of the opening in a sliding tablesaw when the wagon is at an extreme position:
You could drop a cordless drill in that hole. DAMHIKT
-- Dave, Tippecanoe County, IN --- Is there a corollary to Beranek.s Law that applies to dust collection?
Pizzadave
#11 posted 04-25-2020 04:26 PM
Pizzadave
#12 posted 04-25-2020 04:34 PM
Indeed
View Axis39's profile
Axis39
378 posts in 519 days
#13 posted 04-25-2020 04:42 PM
- pintodeluxe
Not being argumentative, really just want to know the logic behind your mention of the throat opening up.
Do you mean, if you pull the sled out of the way, it’s open? Or do you mean that somehow the insert keeps the blade in alignment better?
The reason I ask is because the regular insert that came with my Shopfox is a metal plate, with a fixed opening that is much larger than the thickness of my blade. I cannot imagine depending on the insert to keep my blade in alignment… That sounds kinda scary. But, maybe I’ve misunderstood what you were saying?
-- John F. SoCal transplant, chewer uppper of good wood
Kelly
#14 posted 04-25-2020 05:35 PM
It almost seems as if most the answers are forgetting the sled.
OF COURSE no one familiar with saws would run a table saw without one, when making routine cuts. In fact, most of us have several, because zero clearance not only makes for better cuts, but keeps things from dropping through the gap between the plate and the blade. However, here, the sled is the throat plate.
Another “of course” would be, it, doesn’t hurt to run one with a sled.
All that aside, the dust collection might even be better without one.
Oh, and add to John’s the fact that throat plate gap on many saws will accommodate a blade at 45 degrees and even a narrow dado.
