Forum topic by carolinagene | posted 04-22-2020 11:05 PM | 2422 views | 0 times favorited | 5 replies | ![]() |
Need to make some interior cuts in some 8/4 ipe lumber. What brand/Israel’s jigsaw blade should I use? Should I use oscillation or not? Thanks for any tips! |
5 replies so far
#1 posted 04-22-2020 11:47 PM |
Use a fine tooth wood blades (or “soft metals” blades) and go SLOW. Ipe cuts like soft cast iron and will rapidly dull the blades so have spares. Cut inside the line and sand to it. Don’t inhale the yellow dust. -- The hump with the stump and the pump! |
#2 posted 04-23-2020 12:14 AM |
Is it rough or skip planed already? I wouldn’t want to use a jig saw on rough 8/4 ipe personally. If thats your only choice try to get some longer blades. |
#3 posted 04-23-2020 12:20 AM |
Maybe try a carbide tooth jigsaw blade and go slow. |
#4 posted 04-23-2020 12:39 AM |
SMP…....it’s a smooth board. Thanks for all your tips so far! |
#5 posted 04-23-2020 12:40 PM |
My experience is that you machine Ipe more than cut it. It is one tough wood! That being said, if you don’t have any luck with jig saw (that’s a pretty deep cut) you might try a reciprocating saw with a carbide blade if the cut will allow a drilled starter hole. -- Don't let perfection get in the way of plenty good enough |
Forum | Topics |
Woodworking Skill Share
13543 |
Woodturning
3009 |
Woodcarving
618 |
Scrollsawing
436 |
Joinery
2076 |
Finishing
6709 |
8187 |
34180 |
CNC Woodworking
384 |
Hand Tools
6768 |
Jigs & Fixtures
1920 |
Wood & Lumber
7617 |
1696 |
Focus on the Workspace
2749 |
1295 |
Woodworking Trade & Swap
5576 |
LumberJocks.com Site Feedback
2431 |
Coffee Lounge
9900 |
