Vises
« back to Hand Tools forum
Forum topic by Floyd Hall posted 04-16-2020 09:39 PM 846 views 0 times favorited 17 replies Add to Favorites Watch
View Floyd Hall's profile
Floyd Hall
190 posts in 1511 days
04-16-2020 09:39 PM
Topic tags/keywords: bench vises
Hi all. I recently purchased a set of reconditioned hand planes—a 4, 5, 6 and 7, together with a low angle and a regular angle block plane.
I plan on adding a tail vise to an 8ft table I’m building and a single line of bench dog holes. I’m also thinking of face vise—quick realm woodworkers vise or a leg vise.
Any thoughts?
Floyd
17 replies so far
View Thorbjorn88's profile
Thorbjorn88
229 posts in 1382 days
#1 posted 04-16-2020 09:45 PM
Whichever you choose I recommend having the inner jaw of the vise flush with the front of the bench so that you can clamp long pieces against the bench. I didn’t do this and have found many times this would have been very helpful to the point where I plan on rebuilding the front apron of my bench in the next few months.
-- Dave
View SMP's profile
SMP
4816 posts in 1145 days
#2 posted 04-16-2020 09:58 PM
If you ask 100 people, you’ll get 500 answers, none wrong or right. Interestingly, go on YouTube and search for Mike Siemsen viseless bench, he shows how to work without one. Others like Paul Sellers swear by a quick release vise with a clamp in the vise. I built mine with a traditional english face vise. But for planing i just use a planing stop.
Floyd Hall
#3 posted 04-17-2020 02:20 AM
- Thorbjorn88
Good tip. Thanks.
View therealSteveN's profile
therealSteveN
8832 posts in 1814 days
#4 posted 04-17-2020 04:52 AM
99% of the answer here will depend on the budget you are allowing.
For starting out the low cost vises at Harbor freight do work, just don’t expect the smoothness of action you get from the top of the line vises. But they do work.
-- Think safe, be safe
Floyd Hall
#5 posted 04-17-2020 06:06 AM
Well, one of the things about the leg vise, like the tail vise, is it is cheaper. That’ good. If I need fancier vises later, I’ll buy them. What I need right now is good hold downs for longer boards. They don’t have to be fancy. But I need to be able to secure 8ft boards both for flattening and joining.
Floyd
View Don W's profile
Don W
20179 posts in 3807 days
#6 posted 04-17-2020 11:13 AM
For jointing, the kind of vise doesn’t make a big difference. Just something to clamp upright.
I have both a quick release and a leg vise. I like both.
I don’t typically clamp for the flat, I just use a stop.
View Sylvain's profile (online now)
Sylvain
1389 posts in 3739 days
#7 posted 04-17-2020 12:24 PM
not everybody agrees about the vise flush with the front.
https://paulsellers.com/2014/01/flush-vises/
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
Floyd Hall
#8 posted 04-17-2020 07:42 PM
I don t typically clamp for the flat, I just use a stop.
- Don W
What kind of stop do you use? Forgive me if that’s a dumb question. I really don’t know anything about this.
Floyd
View OleGrump's profile
OleGrump
581 posts in 1584 days
#9 posted 04-17-2020 08:16 PM
My father had a bench with a 1950s vintage quick release vise. I hated the damned thing. It was hard as Hell to get the jaws positioned so that a quarter or half turn of the handle would tighten correctly. Usually, you got back to the slot before you ever got it tightened. Me, personally, I would not ever want to have to fight with another one.
Current bench has a leg vise on front left leg, rear jaw flush with the 2X6 apron. Got the entire vise, parallel beam and all, at flea market for $15, because the seller wasn’t sure what it was. Repurposed the hardware and parallel beam with new lumber for this bench. Works great for me. (Big fan of rear jaw FLUSH with front of the bench.)
That being said, the advise to watch some YouTube videos showing different vises is the best thing you can do. Make notes on which styles you like and may work the best for you. Then you can decide between them which you actually want to install on your bench.
-- OleGrump
Floyd Hall
#10 posted 04-17-2020 08:26 PM
Current bench has a leg vise on front left leg, rear jaw flush with the 2X6 apron. Got the entire vise, parallel beam and all, at flea market for $15, because the seller wasn t sure what it was. Repurposed the hardware and parallel beam with new lumber for this bench. Works great for me. (Big fan of rear jaw FLUSH with front of the bench.)
- OleGrump
Yeah, I’m focusing on the leg vice right now. Would you mind posting a picture of yours?
Floyd
View bigJohninvegas's profile
bigJohninvegas
1095 posts in 2702 days
#11 posted 04-17-2020 09:19 PM
I am using the large Quick release steel bench vise from Lee Valley. See link below.
I thought about making it flush, but in the end I did not.
Has worked fine for me. But that is what worked me. Like others said, not right or wrong way. Just whatever you feel will fit your needs.
With this vise, 1/4 turn releases it, but tightening depends on how hard you push it into the item being clamped.
1/4 to several turns. Its all on you.
Here is the link
https://www.leevalley.com/en-us/shop/tools/workshop/workbenches/vises/49980-quick-release-steel-bench-vises
I have the 10-1/2” vise. They have smaller versions. And other companies have less costly versions that I wonder if they are really the same vise.
Bench was brand new, and I had not added dog holes yet.
-- John
Don W
#12 posted 04-17-2020 09:34 PM
- Don W
What kind of stop do you use? Forgive me if that s a dumb question. I really don t know anything about this.
Floyd
- Floyd Hall
Sometimes it’s just a dowel in the holes in my bench, sometimes I stick a piece of wood in my end vise and let it stick up a little. There are countless ways to make or provide for a plane stop.
View SMP's profile
SMP
#13 posted 04-18-2020 01:07 AM
- Don W
Floyd
- Floyd Hall
If you have dogholes in the top you can get these veritas type for wider boards:
https://www.leevalley.com/en-us/shop/tools/workshop/workbenches/benchtop-accessories/69837-veritas-planing-stop
Or you can get a semi-traditional stop like this, there setup is nice where you can just screw to the side of your bench if you don’t want to mortise the traditional one in:
https://toolsforworkingwood.com/store/item/BT-PS.XX
Another option is making a shooting board like Timothy Rousseau’s that clamps in the vise and you can use as a planing stop.
Don W
#14 posted 04-18-2020 11:45 AM
https://www.lumberjocks.com/donwilwol/blog/33500
My most used vise
https://www.lumberjocks.com/donwilwol/blog/34022
View YouthfullMind's profile
YouthfullMind
84 posts in 1391 days
#15 posted 04-18-2020 12:31 PM
I use my tail vise and leg vise almost equally. The tail vise is mainly used for hand planing and holding pieces that are difficult to clamp because of their shape. I’d say the tail vise is almost a requirement for hand planing. I have one row of dog holes lined up for that vise. I placed a second row of dog holes further back on the bench for using hold fasts. I have both of my vises flush with the surface of the bench; not mandatory, but worth it in the long run.
None of these things are mandatory, but a face/leg vise, and end vise, and hold fasts greatly increase your abiilty to effectively hold/clamp work pieces. Its hard to know what you need until you start using the tools.
