Replacement for an outfeed roller for deta 22-580 planer
Forum topic by Mervyn posted 04-12-2020 05:09 AM 637 views 0 times favorited 6 replies Add to Favorites Watch
View Mervyn's profile
Mervyn
4 posts in 1357 days
04-12-2020 05:09 AM
Topic tags/keywords: question
Hi. I have a deta 22-580 planer with a broken sprocket (part #899355)
Looking online I couldn’t find a replacement since the part is considered obsolete. Anyone else had an issue with this getting this sprocket? Any advise on alternatives?
Thank you
View hcbph_1's profile
hcbph_1
100 posts in 526 days
#1 posted 04-12-2020 07:50 PM
I don’t have a part like that, but if I had a broken sprocket and I couldn’t find a suitable replacement through the normal sources I’d start with farm and industrial supply houses. Many pieces of farm equipment use sprocket and chain setups as do certain industrial equipment items.
Good luck
View CaptainKlutz's profile
CaptainKlutz
4856 posts in 2706 days
#2 posted 04-12-2020 10:15 PM
FWIW:
Universal replacement sprockets are available. Sprockets are defined by chain size, number of teeth, and bore of shaft. Key is to start with chain size.
There are many online sources for chain/sprockets, such as this one:
https://www.rollerchain4less.com/sprocket-diameters
PS – When a sprocket fails in a chain driven system, it is often due chain wear/stretch. Be sure to check you chain dimensions carefully, before returning system back to service. Using a bad chain on new gear will cause the same failure to happen must faster than 1st time.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
Mervyn
#3 posted 04-13-2020 11:52 PM
Thank you. It seems like a weird dimension for a chain. The pitch is 0.5” and the inside width is 0.14”.
View BarrelBoys's profile
BarrelBoys
1 post in 48 days
#4 posted 08-02-2021 08:33 PM
Did you ever find the Sprocket? I have same issue and am having no luck
View Peteybadboy's profile
Peteybadboy
3877 posts in 3161 days
#5 posted 08-02-2021 08:40 PM
try ereplacementparts.com
-- Petey
View tvrgeek's profile
tvrgeek
2255 posts in 2861 days
#6 posted 08-02-2021 09:06 PM
Hope it is generic as there is virtually zero su[port for any pre-buyout Delta.
But, the same generic lunchbox was sold by everyone. Look at parts from all the brands. ereplacement may have one for a Jet of WEN that is the same.
