How big of a dado can I cut on an old craftsman 113 table saw?
Forum topic by knexster posted 04-12-2020 01:14 AM 258 views 0 times favorited 4 replies Add to Favorites Watch
View knexster's profile (online now)
knexster
63 posts in 2018 days
04-12-2020 01:14 AM
I am setting up for a 3/4 dado cut and the arbor doesn’t fully thread, but it’s secure. What is the largest dado anyone has cut using an old craftsman 113? I read that some have removed the arbor washer to accommodate the dado stack. Is this a reasonably safe solution?
This is my current situation. Go, or no go?
Thanks for any tips/answers!
-- Don't think outside the box. Think as if there is no box at all.
View bandit571's profile
bandit571
25586 posts in 3418 days
#1 posted 04-12-2020 01:40 AM
I used to run up to 7/8” wide with a 6” dado set. Yes that washer will have to be removed…but, reverse the arbor nut. So that the bigger flat side is towards the blades. It works…but the sound it makes…....
knexster
#2 posted 04-12-2020 01:59 AM
- bandit571
Thanks for the heads up on the sound! I’ll try it out, and now I won’t turn inside out whenever said “sound” occurs. Lol.
View bc4393's profile
bc4393
91 posts in 1877 days
#3 posted 04-12-2020 02:21 AM
or just use a flat kerf blade an a little ingenuity. I Don’t even mess with my dado set anymore I’m too scared of it.
I use a microjig matchfit dado stop.
https://www.microjig.com/products/dado-stop
Or use this guys method.
https://www.youtube.com/watch?v=KWhT7EGKgGM
knexster
#4 posted 04-12-2020 04:50 AM
Thanks again bandit! I removed the washer and flipped the arbor nut, and it worked great.
