Dado set on Sawstop
Forum topic by Gpilot posted 04-11-2020 09:11 PM 700 views 0 times favorited 9 replies Add to Favorites Watch
View Gpilot's profile
Gpilot
2 posts in 373 days
04-11-2020 09:11 PM
Topic tags/keywords: table saw dado blade
I have Sawstop 3hp professional cabinet saw. Max dado set width 13/16”. I am try to put 3/4” (12/16) dado set but when loaded on arbor with flange there are only a few threads left on arbor to hold the nut. Is this safe? Do I omit the flange and just use the nut? Any solutions to this problem?
9 replies so far
View tvrgeek's profile
tvrgeek
1788 posts in 2708 days
#1 posted 04-11-2020 09:41 PM
Threads should extend past the nut.
What does SawStop say?
View TimInIndiana's profile
TimInIndiana
161 posts in 1199 days
#2 posted 04-11-2020 09:56 PM
Per the manual:
For dado widths larger than about 3/8 inch, do not use the arbor washer. Instead, tighten the arbor but directly against the dado set.
Manual PDF
See page 29.
tvrgeek
#3 posted 04-11-2020 10:29 PM
RTFM. How un-manly. :)
View Foghorn's profile
Foghorn
1162 posts in 445 days
#4 posted 04-11-2020 10:37 PM
- tvrgeek
Ha! I’ve been there before. Similar to RTFC in my business.
-- Darrel
View AndyJ1s's profile
AndyJ1s
485 posts in 813 days
#5 posted 04-12-2020 03:28 AM
Why, readin’ the manual, that’s just plain cheatin’!
-- Andy - Arlington TX
View controlfreak's profile
controlfreak
2001 posts in 660 days
#6 posted 04-12-2020 11:59 AM
I had a similar moment on my jobsite saw (not saw stop) and thought I am not comfortable with this. I ended up making multiple passes. It is nice to know that I can get that last blade on when its close.
View JackDuren's profile
JackDuren
1496 posts in 2018 days
#7 posted 04-12-2020 04:18 PM
The nut should be completely on the threads.
View jkm312's profile
jkm312
87 posts in 462 days
#8 posted 04-14-2020 12:46 AM
Never looked at a Sawstop in detail. I can’t tell from the PDF from above how thick the arbor flange is. On my Unisaw the arbor flange and nut is all one substantial piece. I found using a fender washer gives a larger surface for the arbor nut too hold the dado stack on the arbor. Whatever you do, do not spin that wide of a dado blade without the full threads of the arbor nut in place.
6930 posts in 3552 days
#9 posted 04-14-2020 12:21 PM
Only because I’m desperate for something to do in the shop, I measured the SS flange washer thickness. It’s 3/8”. I had bought the optional nut for my Uni when I had it that had the attached washer, it was a nice addition. However, that set came with a different nut for dado sets that didn’t have the washer on it.
