New Wood shaper for my space has loose motor housing
Forum topic by Jm4721 posted 04-10-2020 03:50 PM 416 views 0 times favorited 4 replies Add to Favorites Watch
View Jm4721's profile
Jm4721
9 posts in 478 days
04-10-2020 03:50 PM
Topic tags/keywords: shaper motor broken repair belts tool workspace
I bought a shaper a few months ago and didn’t get into trying to use it until now. Trying to change the rpms I loosened a couple bolts too much and the motor dropped a little bit.
Now its slanted/drooping and bolted to the main plate and I can’t straighten it. It’s at a 4 degree angle now side to side, not counting straight across the v belt.
Does anyone know anything about this?
I tried to call a tool repair service but they aren’t around for at least a couple weeks.
View Madmark2's profile
Madmark2
2965 posts in 1750 days
#1 posted 04-10-2020 04:27 PM
Lay it on it’s side to take the weight off and tighten everything back like it was. Alternately to tipping it over get a helper to lift the motor while you crank the screws.
The bolts you loosened are for the motor alignment not mounting!
It’s like the old sealed beam headlights, people would twist the adjusters apart trying to loosen the headlight.
Shaper cutters don’t vary in diameter as much as router cutters do so there is little need for speed changes esp. since shapers run much slower than routers to begin with.
-- The hump with the stump and the pump!
View John Smith's profile
John Smith
2982 posts in 1324 days
#2 posted 04-10-2020 04:43 PM
I will show the issue as posted on another site:
O/P has not posted make or model number of his shaper.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View Jared_S's profile
Jared_S
466 posts in 1121 days
#3 posted 04-10-2020 05:02 PM
Ugh I hate that system for motor tension.
Just pull up the motor and tighten the bolts
Jm4721
9 posts in 478 days
#4 posted 04-11-2020 05:09 AM
I think i found the problem.
This is a groove and rail that isn’t working. It seems like the rail slipped out of the groove. I’m going to try a jack and see if I can put it back.
