Another beaded frace frame jig
Forum topic by AlaskaGuy posted 04-09-2020 07:10 PM 220 views 0 times favorited 4 replies Add to Favorites Watch
View AlaskaGuy's profile
AlaskaGuy
5734 posts in 3049 days
04-09-2020 07:10 PM
https://youtu.be/reXh_d9YE5s
View Aj2's profile (online now)
Aj2
2973 posts in 2537 days
#1 posted 04-09-2020 08:19 PM
That’s a nice jig wish I could make jigs that accurate.
Is he not missing some jointery to hold everything together?
-- Aj
View Jared_S's profile (online now)
Jared_S
348 posts in 699 days
#2 posted 04-09-2020 08:42 PM
- Aj2
Pocket screws
View robscastle's profile
robscastle
7092 posts in 2944 days
#3 posted 04-10-2020 03:17 AM
OK having made the same frame joints I need to point out a couple of things.
1 It is only that simple when using stock exactly the same width as the notching cutter.
2. When you use wider outer frames and the rails the process becomes a lot more complicated.
3. As Jared S pointed out the jointing fixing process is not included and biscuits can also be used.
4. Being that narrow almost excludes fitting the euro type hinges of most cabinet door use these days
It then becomes a very labour intensive joint however looking great at the finish.
I guess a matter of personal choice at the end of the day.
It is a brilliant setup he has.
-- Regards Rob
Jared_S
#4 posted 04-10-2020 03:59 AM
- robscastle
To address item #2, use a spacer of the exact width over the width of cut in a single pass. (Your stock still needs to be perfect)
Slightly more complicated jig cutting wide notches with explanations.
https://youtu.be/FvBefqYInhc
#4, not sure what you see as narrow? Euro hinges work fine.
