is stropping necessary
« back to Woodcarving forum
Forum topic by Karda posted 04-09-2020 06:36 AM 593 views 0 times favorited 25 replies Add to Favorites Watch
View Karda's profile
Karda
2201 posts in 1285 days
04-09-2020 06:36 AM
the highest i sharpen is with a 2000 grit diamond plate, is it necessary to strop after that thanks Mike
25 replies so far
View david2011's profile
david2011
13 posts in 4438 days
#1 posted 04-09-2020 07:30 AM
Stropping is not necessary but if you want the best from your chisels and planes you will strop. The cost to get set up is negligible. You can start with a scrap of cowhide or horsehide at least 3”x8” and preferably some green stropping/polishing compound. It only takes a few seconds and leaves the edge much smoother than if you don’t strop. If you want to get fancy get two pieces of leather and mount them on scraps of plywood; one with the rough surface up for the polishing compound and one with the smooth surface up for a final polish without the compound. Still, it only takes seconds and the cost is still small. A well prepared edge can be touched up several times on the strop alone if you don’t put it off so long that the edge has gotten too dull.
-- David
Karda
#2 posted 04-09-2020 07:59 AM
I have strops and compound, but I was wondering if it would matter when I hone on a 2000 grit diamond plate. I have no idea what the grit of the coumpound is, the one I use is red rouge, it about 30 yeard old
View AESamuel's profile
AESamuel
103 posts in 1954 days
#3 posted 04-09-2020 09:19 AM
Red rouge won’t work for stropping blades/irons, it isn’t hard enough. It’s designed for polishing soft metals for jewellery. There are differences between compounds but any buffing/polishing compound designed for steel will work.
Unless you’re willing to shell out for very high grit stones (8-10k+) stropping is the BEST way to finish your blades.
View tvrgeek's profile
tvrgeek
941 posts in 2380 days
#4 posted 04-09-2020 10:11 AM
I recently learned how to strop. I not keep it handy for any hand powered tool. I hone to 3000 first.
View controlfreak's profile (online now)
controlfreak
688 posts in 332 days
#5 posted 04-09-2020 10:30 AM
Maybe not a critical step but I sure enjoy looking at that polished edge. At the low ost to get a piece of leather and some rouge why not.
View Clarkhus's profile
Clarkhus
53 posts in 328 days
#6 posted 04-09-2020 10:39 AM
Check out Stumpy Nubs. He just released some videos on the importance of using a strop.
-- Clark
View Planeman40's profile
Planeman40
1491 posts in 3492 days
#7 posted 04-09-2020 01:47 PM
What many don’t understand is that thin, fine, sharp edge often get bent to one side under use. Stropping straightens it back out. This is also the purpose of the sharpening “steel” used by chefs. It straightens out the already sharp edge. Sharpening “steels” also work well on woodworking edges.
View ChefHDAN's profile
ChefHDAN
1596 posts in 3581 days
#8 posted 04-09-2020 02:25 PM
...sharp edge often get bent to one side under use. Stropping straightens it back out. This is also the purpose of the sharpening “steel” used by chefs. It straightens out the already sharp edge. Sharpening “steels” also work well on woodworking edges.
- Planeman40
100% correct in the kitchen we use stones to Sharpen, and a steel to Hone the edge. I have a 6” diamond steel that I keep on my bench that gets frequent use for most everything with an edge.. lol even my Katanas
View Robert's profile
Robert
3700 posts in 2212 days
#9 posted 04-09-2020 02:47 PM
- Karda
OK, let’s get ‘er started…...:-D
Stropping is not necessary.
Go to at least 6K.
Personally I go to 12K.
I strop but I don’t really know why.
View Madmark2's profile
Madmark2
1256 posts in 1319 days
#10 posted 04-09-2020 03:19 PM
It’s not just the grit that matters. Stone sharpening forms a ‘wire’ on the edge that stropping removes. This is most easily felt on the edge of a scraper but exists on most any stone sharpened edge.
The hardness of the stone just flops the wire from one side of the edge to the other and never really removes it (since the action of the stone created the wire, more stonework ain’t going to remove it).
Going to a softer strop helps flex, roll, and break the wire free. Leaving the edge clean and at ultimate sharpness.
-- The hump with the stump and the pump!
Planeman40
#11 posted 04-09-2020 03:31 PM
That is true about the “wire edge”. A better way to remove it is to jab the edge into the end grain of a softwood block. This knocks the wire edge really nice.
View HokieKen's profile (online now)
HokieKen
13495 posts in 1869 days
#12 posted 04-09-2020 03:42 PM
Try stropping for a while and see if it makes any difference in the quality or durability of the edge. If you don’t notice an improvement, you don’t need to strop. If you do notice an improvement, then keep stropping.
-- Kenny, SW VA, Go Hokies!!!
Madmark2
#13 posted 04-09-2020 03:48 PM
Stropping is done with the edge, stone is used against the edge.
Certainly barbers have been stropping blades since the invention of iron because there is no benefit to the edge …
View WoodenDreams's profile (online now)
WoodenDreams
1032 posts in 642 days
#14 posted 04-09-2020 04:00 PM
Stropping is not necessary, but do you want sharp, super sharp or scary sharp.
Karda
#15 posted 04-09-2020 05:40 PM
ok thanks
