Shop vac to pocket hole jig
Forum topic by BlasterStumps posted 04-05-2020 09:54 PM 191 views 0 times favorited 0 replies Add to Favorites Watch
View BlasterStumps's profile
BlasterStumps
1688 posts in 1216 days
04-05-2020 09:54 PM
My dust control hook up to the pocket hole jig:
I cut the bottom end off of an old popup sprinkler housing. Then using a hole saw, I drilled the threaded end out to approximately the size of the vacuum adapter of the pocket hole jig. Then I enlarged it just so it fits snugly on the pocket hole adapter piece. I cut off the hose connection portion of an old floor tool from a vacuum set, heated it and made it slip over the sprinkler housing part. I drilled some holes around on two sides of the sprinkler part until I could hear that the vacuum wasn’t laboring when it was going. I gave it a good test. Works very well. No more mess when I am drilling pocket holes. Yay!
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
0 replies so far
