Help on identifying wood
Forum topic by RevisitingWood posted 04-04-2020 03:15 PM 277 views 0 times favorited 4 replies Add to Favorites Watch
View RevisitingWood's profile
RevisitingWood
1 post in 59 days
04-04-2020 03:15 PM
Topic tags/keywords: help wood identification
First post and I thank everyone in advance for their help. I’m restoring an old back bar I inherited. I’m confused as what kind of wood this is on the bar. The bottom piece on the side is oak and the top piece is pine.
I need to replace a few pieces of wood and want to match so stain looks consistent. I went to look at lumber yesterday and got a bit confused without having anything from it with me. If anyone can look at the grain pattern etc and help, I would appreciate it! Here is the image from the other side for another look.
View CaptainKlutz's profile
CaptainKlutz
3027 posts in 2231 days
#1 posted 04-04-2020 03:24 PM
Welcome to LJ!
The pictures do not show the grain, color, and end grain with enough detail to even offer a guess?
I use these sites to help me identify wood:
https://www.wood-database.com/wood-finder/
http://www.hobbithouseinc.com/personal/woodpics/
Best Luck.
View LesB's profile
LesB
2515 posts in 4180 days
#2 posted 04-04-2020 05:33 PM
It could be Alder and even if it is not I think Alder might be a good substitute for what you have. Alder is relatively inexpensive so you could get some and try you stain on it. The mantra with staining is….test….test…test first.
Alder is a fairly soft wood so it this wood is not “soft” it is hard to tell.
-- Les B, Oregon
View Aj2's profile
Aj2
2966 posts in 2535 days
#3 posted 04-04-2020 05:49 PM
It could be old growth Douglas fir.
Old fir has a particular smell and texture and is very soft.
It’s a wild guess
Good Luck
-- Aj
View Phil32's profile
Phil32
1059 posts in 640 days
#4 posted 04-04-2020 06:14 PM
All wood is variable even within a species. It will vary if flat sawn vs. quarter sawn. You can come close to matching woods by the way you stain & finish the final assembly.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
