Filling small cracks 8nnpens or knife scales
Forum topic by Mark Shultz posted 04-03-2020 02:36 AM 188 views 0 times favorited 6 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
145 posts in 3119 days
04-03-2020 02:36 AM
What do you all use to fill small cracks in stabilized or non stabilized pen blanks or knife scales?
View LesB's profile
LesB
2506 posts in 4172 days
#1 posted 04-03-2020 05:12 PM
Medium thick CA glue should work. If cracks are large enough add fine sawdust to match wood first.
-- Les B, Oregon
Mark Shultz
#2 posted 04-03-2020 05:41 PM
Thanks Les. Any brand suggestions? I’ve not used CA before.
View HokieKen's profile
HokieKen
13476 posts in 1868 days
#3 posted 04-03-2020 05:51 PM
Yep, super glue is what I use too. I prefer the thin stuff though for small cracks. If it’s large enough you can pack sawdust into it, then medium will work better.
-- Kenny, SW VA, Go Hokies!!!
View pottz's profile
pottz
9362 posts in 1714 days
#4 posted 04-03-2020 05:56 PM
any brand of ca will work ive used different brands never found a difference really.
View LittleBlackDuck's profile
LittleBlackDuck
4417 posts in 1550 days
#5 posted 04-04-2020 11:57 AM
For larger cracks…
  • For similar/same colour, I keep a swag of fine shavings of most popular timbers which I mix/apply using CA,
  • For contrasting color, I use a paste of charcoal powder/CA for non-CA finishes and for CA finishes I use simple woodfiller as the CA will seal and strengthen it,
- pottz
Just don't stockpile.
View LesB's profile
LesB
#6 posted 04-04-2020 05:17 PM
I suggested the medium thick CA glue because it takes a minute or so for it to set up and that allows it to soak into the crack (or sawdust). For this application I also think most brands are acceptable. I use Stick Fast because the local WoodCraft store carries it in the 4.5 oz bottles.
I hardly ever use the thin glue for wood working EXCEPT when I’m filling a larger crack or hole with sawdust. Then I use both glues. First the thin and immediately the medium. The thin acts as a wicking agent for the medium and I get better penetration into the sawdust.
I too save different wood sawdusts in small containers. I usually collect it with my orbital or belt sanders which have dust collecting bags attached.
-- Les B, Oregon
