White Chalky Film on SYP Tongue and Groove Ceiling
Forum topic by OLCHIEF posted 04-02-2020 08:28 PM 420 views 0 times favorited 11 replies Add to Favorites Watch
View OLCHIEF's profile
OLCHIEF
35 posts in 121 days
04-02-2020 08:28 PM
My house was built in 1986. The living room walls and vaulted ceiling are tongue and groove southern yellow pine with some type of clear finish. Over the past year I have noticed a white chalky film on the surface of the ceiling boards. It wipes off and feels like chalk dust. I am thinking the varnish they used is breaking down but I thought I would ask the experts here if you have seen this before.
-- OL CHIEF, Florida Panhandle
11 replies so far
OLCHIEF
#1 posted 04-03-2020 05:36 PM
I must have a new discovery
View ibewjon's profile
ibewjon
1545 posts in 3533 days
#2 posted 04-03-2020 07:09 PM
Better get a patent guick, before an interior decorator spreads the idea!
OLCHIEF
#3 posted 04-03-2020 09:54 PM
- ibewjon
If I could work a sliding barn door in there we could make a fortune!
View CaptainKlutz's profile
CaptainKlutz
3041 posts in 2234 days
#4 posted 04-04-2020 12:49 AM
Possible causes:
1) Water spots: Dried condensation left behind minerals marking finish.
2) Damaged Finish: Mechanically abraded, or water soaking has created holes and edges of finish are white.
3) Mineral or Resin seeping out of the base lumber due water exposure.
Only close destructive examination will find #2-3. #1 can be found by applying heat and moisture to hydrate the minerals.
4) Need to have eyes checked for floaters, or maybe need new glasses. LOL
Best Luck. :-)
View BlasterStumps's profile
BlasterStumps
1644 posts in 1179 days
#5 posted 04-04-2020 02:19 AM
We run a small table-top humidifier and as a result get a light efflorescence coating noticeable on the windows that is similar to what you are describing.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View GrantA's profile
GrantA
2431 posts in 2147 days
#6 posted 04-04-2020 02:25 AM
Chief have you been in the house since 86?
Has anything changed in the past year or so you’ve noticed this?
Did it seem to be a clear finish originally?
OLCHIEF
#7 posted 04-04-2020 11:56 AM
Has anything changed in the past year or so you ve noticed this?
- GrantA
Yes we have been here many years. The only thing really different is last year we had hurricane mitigation retrofitting done where they used a closed cell foam adhesive to glue the bottom of the roof sheathing to the tops of the trusses but that should not have touched the top side of the T&G boards. We also had an exceptionally wet winter and I am wondering if that might play a role.
OLCHIEF
#8 posted 04-04-2020 11:57 AM
- GrantA
And yes the finish was clear
- OLCHIEF
View Heyoka's profile
Heyoka
47 posts in 592 days
#9 posted 04-04-2020 12:37 PM
Better get it checked for mold!
-- Heyoka
View splintergroup's profile
splintergroup
3681 posts in 1962 days
#10 posted 04-04-2020 02:43 PM
I installed 4” T&G pine on several ceilings in my house circa 2000. Pine with WB poly. No issues what-so-ever but this is the southwest and quite dry, though a swamp cooler runs in the summer (humid) and a pellet stove in the winter (dry).
I’d bet on moisture/condensation fi I had to make a guess. Can you wipe/scrub/scrape clean an area and see if it returns?
OLCHIEF
#11 posted 04-04-2020 05:01 PM
We are mopping the ceiling with Murphy’s Oil Soap and also trying Liquid Gold to day. It is cleaning up ok.
