Forum topic by Madmark2 | posted 04-02-2020 01:00 AM | 862 views | 0 times favorited | 19 replies | ![]() |
Topic tags/keywords: tip safety push block hand guard rip For about ten years I’ve been using the Hand Guard table saw push block. This is, IMHO, one of the simplest and most elegant thin rip push block I’ve ever seen. This tool has a channel that the blade passes thru while applying downward pressure on either side of the kerf. The heel adjusts to different stock thickness with a quick click. The sides of the channel are only about 1/8” wide so you can easily rip 3/16” strips between the blade and the fence. Mine finally gave up the ghost when I got a little sloppy and shaved half of one of the channel sides about off (oops). I recalled ordering it from one of the catalog co’s but I couldn’t find it anywhere. Finally I tried the URL on the device. I found what appears to be a dead site with just an email entry page. I filled it out and about a half hour later got a call from the owner of the company. He explained that they had gone out of production about four years ago but that they had just resumed production this spring. Well he gave me the new & improved website: https://www.jarmstools.com I’m not getting anything for this but this is a great simple tool that rivals a Grrripr block but without the knobs (but still adjustable and a lot less). It’s made in the USA and the owner is also the shipping department. Joe Bob sez “Check it out!” -- The hump with the stump and the pump! |
19 replies so far
#1 posted 04-02-2020 01:15 AM |
I’ve got one of those stashed away somewhere. |
#2 posted 04-02-2020 01:21 AM |
The ONLY way to push wood past a blade. I’m to cheap to go this route, so I make my own. I have them in various thicknesses by making them from scrap Masonite and plywood. Too, they have different sole depths, so pushing a pieces of Formica or other laminate through the blade is no big deal. I believe in these so much, this is my storage area for them. |
#3 posted 04-02-2020 01:59 AM |
I’ve been looking at the Micro Jig GRR-Ripper. The Hand Guard is much less expensive. Maybe not quite as versatile. -- Andy - Arlington TX |
#4 posted 04-02-2020 02:12 AM |
I think the Hand Guard has superior visibility over the Grrr-ripper. -- The hump with the stump and the pump! |
#5 posted 04-02-2020 02:29 AM |
I think I’ll stick with my 1/2” BB hand cut version that has done me well for the last 25+ years. If I were going to buy something, it would be the Gripper by far. Why go half way? |
#6 posted 04-02-2020 02:49 AM |
Ones you make yourself don’t push both sides of the blade without getting cut up. The Hand Guard straddles the blade with positive push from the heel. No rubber pads to slip. It gives Grrr-ripper a run for a fraction of the cost. -- The hump with the stump and the pump! |
#7 posted 04-02-2020 03:16 AM |
When it gets cut up, the middle is missing, just like Hand Guard. -- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine |
#8 posted 04-02-2020 03:26 AM |
I can’t think of a time I have ever needed to push both sides. |
#9 posted 04-02-2020 03:58 AM |
Come on, you aren’t saying we retired pros, decades in, were doing it all wrong, for decades, are you? If I showed you the back of some of my wide pieces, they’d show you right. But, as another says, what of it? I make new ones as I please. Too, I make them and give them away, in hopes others will use them. It is because I use a 3/4” pieces of ply to push through a cut out of the bottom right (to make 1/8” x 1/8” strips, for example) that I can do that all day long, with only a couple launches (another part of experience is, knowing not to stand behind the projectile). No need to defend your toy. We agree, it’s a fine one. Finally, there is that our cheap and less purty ones may be thought of as being, somewhat, akin to running the blade through a sled for a bandsaw or tablesaw. Just keep in mind, the new kid or the broke one is better off with the disposable one rather than going without. Then, for me, while I like yours, it would only be a matter of time before I ate up one side or the other of it, then I’d be pissed or disappointed.
#10 posted 04-02-2020 04:21 AM |
Depending on which version you get (or if you purchase the gravity heel add-on), the Gripper does not have to depend on rubber pads gripping either. But it would be much more aggravating if you cut a Gripper up on your saw, than a tried and true, shop-built-from-scrap one. -- Andy - Arlington TX |
#11 posted 04-02-2020 04:26 AM |
You never cut lexan or formica? They rattle like hell but downward pressure on both sides of the kerf stop the chattering. -- The hump with the stump and the pump! |
#12 posted 04-02-2020 06:36 AM |
That’s why I mentioned the shallow heel for laminate, above. For narrow laminate and plastic cuts. Those cuts are the rare exception. Usually, yours, mine and the Gripper are impractical for most the laminate pieces I cut. There is no reasonable way to manage the push shoes and a large sheet, which requires both hands and, usually, keeping the laminate bent (curved) a couple feet off the table top and dropping it down at the last of the cut. |
#13 posted 04-02-2020 07:09 AM |
Hello Back to the world of wood working Thank you for putting your eyes an words out their for
us all to learn from, as the inventor of the Hand Guard Aid safety tool ,no one tool is a do all ,how i have made the Hand Guard is its not just for Table saws try with any other store bought push stick / push block , or home made splintering-wood cut out wanaB push stick , just ask your self where have you seen a push stick / push block that can go from ripping , and then with a flick of the wrist it now has 3 points of 100% Aid holding power, Hand Guard is seen here with the back Heel in the Ripp, only up an down positions,you can see by setting the blade height so to keep the cutting teeth so they never protrude more then 1/4 inch above the wood stock to be cut, by having both legs of the Heel pushing from both sides of the saw blade ,this can Aid in almost, eliminating un-wanted kickback. By revolving the Heel in to the Shape only position,Yes now you have 3 way holding your wood stock #1 pushing inward, #2 pushing down-word and
#14 posted 04-02-2020 10:35 AM |
Looks interesting enough to watch the video! To OP, thanks for alerting us! |
#15 posted 04-02-2020 01:48 PM |
You never cut lexan or formica? They rattle like hell but downward pressure on both sides of the kerf stop the chattering. I’ve probably cut 100 times more of it than you. I have a laminate slitter for plastic laminate. The plastic “hand guard” is good for the hobbyist. It’s definitely better than nothing. My argument is that it doesn’t do any better than a ”home made splintering-wood cut out wanaB push stick” To pushstickforall, I understand you’re trying to sell your product, (kuddos) |
Forum | Topics |
Woodworking Skill Share
13199 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6346 |
7906 |
32763 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7277 |
1633 |
Focus on the Workspace
2633 |
1272 |
Woodworking Trade & Swap
5417 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9659 |
