Parabola Routing Jig?
Forum topic by totalrewind posted 03-31-2020 06:38 PM 503 views 1 time favorited 19 replies Add to Favorites Watch
View totalrewind's profile
totalrewind
61 posts in 3003 days
03-31-2020 06:38 PM
Topic tags/keywords: jig question
What I want to do is to be able to make a large wooden parabola for focusing sound.
I picture starting with a glue-up of rings with a router that cuts a path through them to refine the shape.
If you can read my MS Paint scribbling, something like this (cutaway side view):
Now, if I wanted a circle, that would be relatively simple. All I’d need is a central pivot. But my question is, can anybody suggest a mechanism to do a parabolic curve instead? (My gut tells me there ought to be some kind of linkage that could do this)
-- For more projects (not just woodworking) check out my project blog at http://theheadlesssourceman.wordpress.com
19 replies so far
View Walker's profile
Walker
344 posts in 1203 days
#1 posted 03-31-2020 06:42 PM
Do you mean a parabola in one plane…or in all dimensions, like a satellite dish? You could do it with an adze and some patience.
-- ~Walker
totalrewind
#2 posted 03-31-2020 06:46 PM
- Walker
Like a dish. (Although even if I could figure it out in 2d, I could just put the thing on a lazy suzan and cut&turn, cut&turn, etc.)
View DaveMills's profile
DaveMills
16 posts in 130 days
#3 posted 03-31-2020 07:00 PM
Here’s a start… https://www.youtube.com/watch?v=lVbfLlSLrZA
Getting to 3D will be interesting :)
View tvrgeek's profile
tvrgeek
941 posts in 2380 days
#4 posted 03-31-2020 07:55 PM
Just get a Miro Snow Sled. As we learned in the early Microwave era, they were a really good parabola!
No help on industrustables either I see. Bust I can suggest is making a 2D template and sand to fit.
View Dark_Lightning's profile
Dark_Lightning
4044 posts in 3840 days
#5 posted 03-31-2020 10:07 PM
When I taught physics I made two 8 foot diameter parabolas for one demonstration. The structure was 1/2” plywood cut in the parabolic shape, and then had paper glued to them. That means that the sections of paper between the ribs were flat, not following a circular path. Still had plenty of gain for the purpose of the demonstration. How big do you want to make the reflector? I watched the video, but it was simple enough to lay out points and connect them with a pencil line and cut the ribs out. They were rectangular with 1/2 the parabola cut in each of them.
-- Steven.......Random Orbital Nailer
View Kazooman's profile
Kazooman
1464 posts in 2683 days
#6 posted 03-31-2020 10:41 PM
Gonna make one of those microphones that can hear what the neighbors are saying? Or the opposite focussing a beam of high intensity sound to pulverize anything in its path? Either way I love the concept. I just have no clue how you would do this with a router sled as you suggested. Any router would have a good sized base to its frame. The bit would have to extend a huge distance to do the cutting while keeping the base from rubbing on the surface. Some sort of industrial overhead CNC machine with no need for a support base night work, but probably not a standard router.
I think the “many parabolic ribs with something in-between” like Steven suggested might be an easier approach. Figure out how to do the layout and cut them on the bandsaw.
Walker
#7 posted 03-31-2020 11:09 PM
how large is large? Too big for a lathe?
-- ~Walker
View waho6o9's profile
waho6o9
8879 posts in 3308 days
#8 posted 03-31-2020 11:37 PM
Look Around 7:34
https://www.youtube.com/watch?v=uvUQyAJ0r14
Best of luck
View JackDuren's profile
JackDuren
1133 posts in 1690 days
#9 posted 03-31-2020 11:48 PM
This jig I found on Woodnet many years ago. You move the jig and not the wood. Change the radius you dont change the jig. I believe you can make this to a 12”- 24” radius….
totalrewind
#10 posted 04-01-2020 03:19 AM
Close, though hopefully not pulverizing anything. :) I was just thinking about doing one of those narrow-beam speakers like they sometimes have in museums, only for a lobby information desk. That way people standing in front of a “welcome” video would be able to hear it, and nothing else… meanwhile everybody else, vice-versa.
After looking into this a little more, now I’m thinking I may be making this too difficult. Why not do the same kind of router jig that people use to hollow out chair seats, only with a (yet-to-be-determined) parabola profile? Do you guys think that might work??
View therealSteveN's profile
therealSteveN
5545 posts in 1305 days
#11 posted 04-01-2020 04:45 AM
Look Around 7:34
Best of luck
- waho6o9
I’m not sure which came first, looks like the same principal.
Seems if you based it on a Lazy Susan, you could swing 360 to make a dish. Arm stays still, and part rotates maybe? I also saw one years ago, where the swing went side to side from a pair of arms. Doing that you could drop the Lazy Susan.
https://www.woodomain.com/online-store/The-JKB-Universal-Routing-table-Ebook-p158404091
-- Think safe, be safe
Walker
#12 posted 04-01-2020 05:37 AM
I googled parabolic speakers and got some very expensive results, a few cheap “cell phone” amplifying devices that looked like little more then bowls. And a few DIY tutorials on how to make your own, using a bowl. You could try to find a wooden bowl that is more parabolic then spherical. Or make one on a lathe.
Honestly I think 3D printing is better suited for this. I have no idea what the cost is, but there are websites you can send a file and they will 3d print for you.
Of course being woodworkers, we understand the fun and challenge of making it yourself. Even if the cost ends up being higher. I still say a solid piece of hardwood, an adze, and some time is all you need. Not that I’ve ever used an adze myself, but that Woodwright fellow makes it look easy!
-- ~Walker
View Tony1212's profile
Tony1212
428 posts in 2466 days
#13 posted 04-01-2020 01:21 PM
Do you have a lathe and any experience turning bowls? This seems right up a turner’s alley.
If not, I would go with the chair seat jig with parabolic rails.
-- Tony, SW Chicago Suburbs
View Sylvain's profile
Sylvain
1027 posts in 3230 days
#14 posted 04-01-2020 05:44 PM
Maybe doing it in more phases:
1. doing a convex parabola (no need for a long bit)
2. making it abrasive (paint + sand?);
3. make a concave form approximately parabolic;
4. using the convex abrasive parabola to refine the convex one.
Now,
- wood might not be the best sound reflector;
- it doesn’t need to be perfect for this application (it is not an optical telescope) so an approximation with straight (conical in fact) segments is probably good enough.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View gwilki's profile
gwilki
344 posts in 2205 days
#15 posted 04-05-2020 01:36 PM
If you have access to a CNC router, it would be and easy carve.
Otherwise, take a look at Izzy’s Youtube site. He has another jig to cut parabolas/bowls on a table saw.
-- Grant Wilkinson, Ottawa ON
