Does anyone know how to cut the rings on a dizzy bowl??
« back to Woodturning forum
Forum topic by Arlin Eastman posted 03-29-2020 01:55 AM 593 views 0 times favorited 12 replies Add to Favorites Watch
View Arlin Eastman's profile
Arlin Eastman
4333 posts in 3291 days
03-29-2020 01:55 AM
I am wanting to glue up some of the wood that is being sent and would like to make several dizzy bowls or vases but do not know how to cut the rings.
Just planning to do this in the future.
Thanks
-- It is always the right time, to do the right thing.
12 replies so far
MrUnix
7987 posts in 2928 days
#1 posted 03-29-2020 07:17 AM
What do you have in the way of a saw to do it? Band saw? Scroll Saw? There are a couple of good videos online that show the process. Lots of work but really cool results. Here is a pretty good video by Dennis Edwards showing how he did one with just a bandsaw and splitting the block in half because he could only re-saw up to 6”.
Dizzy Bowl by Dennis Edwards (YouTube)
View Al Breit's profile
Al Breit
86 posts in 2623 days
#2 posted 03-29-2020 12:24 PM
I am pretty new to the turning is there a program Dennis Edwards is using in the video on youtube to calculate these bowls out?
-- Al Breit "A day without sawdust is like a day without sunshine"
Arlin Eastman
#3 posted 03-29-2020 03:25 PM
I have the grizzly G0555 and the Grizzly G0636x. I also have the DeWalt scrollsaw so I have the right things to do it with all the guys.
View Wildwood's profile
Wildwood
2853 posts in 2864 days
#4 posted 03-29-2020 03:30 PM
Arlin, there are so many ways based upon design for cutting & gluing suggest going to You Tube and type, “wood turning dizzy bowls or twister.” Here are just two examples.
https://www.youtube.com/watch?v=pNBtTqMWlJM
https://www.youtube.com/watch?v=C98F8fmOXnU
Good luck with it!
-- Bill
View Jim Jakosh's profile
Jim Jakosh
24503 posts in 3835 days
#5 posted 03-29-2020 03:47 PM
Hi Arlin. That spreadsheet that Dennis used would be a mighty handy tool for construction of this type of bowl. i’m planning no ding something like that in cutting board.
Cheers, Jim
Arlin Eastman
#6 posted 03-29-2020 05:44 PM
Hi Jim I miss you a lot in visiting. :)
Do you have his spreadsheet??
Bill
Thank you for the links
I watched the first link and realized for each .25” cut of the 4 plates he had a drawing for each one of different ring widths so when he put the sheets together they were .25” apart. So I now know how to do that.
I wonder if it is different with a vase on how it is cut??
View gwilki's profile
gwilki
344 posts in 2203 days
#7 posted 04-01-2020 12:01 AM
I use a scroll saw to cut out my rings. You drill a hole just big enough to thread the blade through. Drill one hole per ring.
You do need different calculations if you want to turn a shape that is not a straight funnel shape. It needs a lot more boards to make the rings, since you don’t get a consistent increase in the diameters.
Here is Tom Lohman’s version showing a more usual bowl shape.
https://www.youtube.com/watch?v=C8guS6VSGBg&feature=emb_logo
-- Grant Wilkinson, Ottawa ON
View SMP's profile
SMP
1996 posts in 635 days
#8 posted 04-01-2020 12:09 AM
Hey, i have a medium flat rate box full of maple scraps with your address on it. Was gonna wait until off lockdown but the governor ordered another month. So will find a day to get to the PO here sometime this month. Crazy times.
Arlin Eastman
#9 posted 04-01-2020 02:10 AM
You do need different calculations if you want to turn a shape that is not a straight funnel shape. It needs a lot more boards to make the rings, since you don t get a consistent increase in the diameters.
Here is Tom Lohman s version showing a more usual bowl shape.
- gwilki
Thanks Grant I think that is a great idea.
Arlin Eastman
#10 posted 04-01-2020 02:12 AM
- SMP
Please wait. I do not want anyone sending us their scrap lumber to get sick. Plus it will defeat the purpose of helping others if friends get sick.
View Snowbeast's profile
Snowbeast
131 posts in 2068 days
#11 posted 04-01-2020 02:13 AM
I know a gent that glues up and preps his thin layers and then uses double faced tape to attach them to a flat disk on his lathe. He uses a thin parting tool to cut rings and then assembles them in the order he wants. He starts with same size layers but adjusts each ring to accommodate the slope he wants to end up with.
Basically this is what Grant described above but using a lathe chisel instead of a scrollsaw.
Or take a look at this if you have a mind to acquire a Ringmaster – https://www.lumberjocks.com/projects/380129
Arlin Eastman
#12 posted 04-01-2020 02:19 AM
Thanks for the idea. A ringmaster is WAY out of my budget and would get some quality tools for turning instead of some of the carbon ones I use and give away to the guys.
