Festool Dust Extractor (shop vac)
Forum topic by MNgary posted 03-27-2020 11:11 PM 216 views 0 times favorited 4 replies Add to Favorites Watch
View MNgary's profile
MNgary
318 posts in 3153 days
03-27-2020 11:11 PM
Topic tags/keywords: dust extractor festool miter saw
Looking for a source to purchase a vacuum cleaner hose that will fit the 26/27 mm exhaust port on a Festool miter saw. I made the mistake of purchasing a Festool miter saw without realizing I need a $640 Festool dust extractor to fit what seems like a proprietary fitting on the exhaust.. I am thinking if I could purchase a vacuum cleaner hose with an inside diameter of 1-1/4 inches, I could make it work and save $500 or more.
Thanks.
-- I dream of a world where a duck can cross the road and no one asks why.
View tvrgeek's profile
tvrgeek
946 posts in 2386 days
#1 posted 03-27-2020 11:35 PM
THere are some generic stepped hose ends. I use some aluminum and foil tape for a while on my chop saw
Welcome to Festool.
I use a generic hose kit on my Fein vac.
Also look at everything in the way of plumbing fittings, or look at various tubes from McMaster Carr you could glue together.
View Clarkhus's profile
Clarkhus
53 posts in 334 days
#2 posted 03-28-2020 12:07 PM
I bought this hose on Amazon. The fittings that come with it works with Festool.
Cen-Tec Systems 94192 16 Ft. Hose for Home and Shop Vacuums with Multi-Brand Power Tool Adapter for Dust Collection, Silver https://www.amazon.com/dp/B07NZZZ5ZL/ref=cm_sw_r_cp_tai_R2ZFEbQJ4ZGAQ
-- Clark
View JackDuren's profile
JackDuren
1153 posts in 1696 days
#3 posted 03-28-2020 02:44 PM
I used a sump pump hose on the two at work. 50’ run and worked fine. The shop vac was far away…
Sump pump hose can be stiffer, but lots cheaper….
MNgary
#4 posted 03-29-2020 06:42 PM
Thanks for sharing. I’ll start looking in the places mentioned.
