Trimmer vs Router
Forum topic by bronxtale posted 03-24-2020 02:39 PM 536 views 0 times favorited 22 replies Add to Favorites Watch
View bronxtale's profile
bronxtale
10 posts in 1964 days
03-24-2020 02:39 PM
Hello,
Need help.
Which router do I buy?
Main purposes:
Edging charcuterie boards, some coffee tables, table bench
No furniture at all.
Will the trimmer be more than enough as it comes with a plunge (Makita) and I like that its handheld vs having to hold the knob base.
Or do I just purchase the 2.25Hp makita right now and be done?
Just a hobbyist having fun.
Thanks for any advice
22 replies so far
View Heyoka's profile
Heyoka
57 posts in 657 days
#1 posted 03-24-2020 02:54 PM
For trim work a trim router is easiest. I use my trim router more than any other one I have in my shop.
-- Heyoka
View pintodeluxe's profile
pintodeluxe
6175 posts in 3617 days
#2 posted 03-24-2020 03:00 PM
A trim router will limit you to 1/4” shank bits only.
I use my 2hp DeWalt more than anything. I have a few trim routers and they’re okay for light duty work. One compact router kit that comes close to meeting all my needs is the DeWalt 611.
View JackDuren's profile
JackDuren
1258 posts in 1764 days
#3 posted 03-24-2020 03:10 PM
Trim router work well for laminate and small things like 1/8,1/4 round over amongst other small tasks. 3/8, Roman ogees, etc I would usd a regular router…
View tvrgeek's profile
tvrgeek
1007 posts in 2453 days
#4 posted 03-24-2020 03:46 PM
Must be why so many folks have so many routers. So the answer is “yes”.
One in the table, one for hand held, my old 1/4 for circle cutting.
View DaveMills's profile
DaveMills
21 posts in 203 days
#5 posted 03-24-2020 04:00 PM
Given that we all know that eventually you’ll have more than one router, I say start with the trim router because it’s a very handy tool. Dealing with various edges on cutting boards and small tables – I’d be using a trim router. And then if (and likely when) you need to do something only a larger router can do, then make that decision.
View Andre's profile
Andre
3622 posts in 2610 days
#6 posted 03-24-2020 04:00 PM
I use a Ryobi 18v cordless trimmer all the time, even built a small sled to do 1/8” to 1/4” groves for boxes.
View kkaucher's profile
kkaucher
24 posts in 1124 days
#7 posted 03-24-2020 04:11 PM
From your description, a trim router is what you want for now. Once you use it for a while and discover how incredibly useful it is, you’ll want a bigger one. That Makita 2 1/4 will be following you home soon. You’ll put both to good use, and you’ll have a backup.
As with so many other implements, two is one and one is none.
-- A bad day woodworking is better than a good day working. ~Author unknown
View bondogaposis's profile (online now)
bondogaposis
5803 posts in 3155 days
#8 posted 03-24-2020 04:14 PM
Well in the end you can’t have just one router. It sounds like the trim router will suit your needs. I have found that a trim router will work for most hand held routing tasks.
-- Bondo Gaposis
View ChefHDAN's profile
ChefHDAN
1700 posts in 3654 days
#9 posted 03-24-2020 05:12 PM
As a fellow hobbyist I would offer another perspective, since you’ll find the limitations of a trim router, FAR quicker than you would with a good 2 base starter kit. My first router was the PC690 2 base kit, but PC isn’t what it once was, If I was in your shoes, I would look at these;
Bosch Kit
Dewalt Kit
As you get deeper into the hobby and learn what you can do with a router, you’ll soon be looking to put the fixed base into a table and shopping for more bits and learning that 1/2” shanks are what you’ll find on most of the bits. I recently, (15 years into hobby), did buy the Dewalt 611 trim router with the 2 base kit and I do love it, but there have been times when I’ve tried to use it for a quick job just to realize I don’t have the profile I want to use in 1/4” shank.
bronxtale
#10 posted 03-24-2020 05:55 PM
Most of the wood is black walnut, spalted maple.
Does this change anyone’s opinions?
Can you plunge good with the trim router?
JackDuren
#11 posted 03-24-2020 06:04 PM
What are you plunging?
View clin's profile
clin
1114 posts in 1800 days
#12 posted 03-24-2020 06:09 PM
I really like my Dewalt DWP611, 1-1/4 HP compact router. It’s handheld but you can get a plunge base for it. It’s bigger than a trim router and smaller than a full size. Yet it’s big enough for most everything I’ve needed to do. Yet works great as a trim router. It will do edging very well.
If I were to get one router or a first router, this is the one I would get. I have an old full-size router, but that just stays installed on a router table. So the Dewalt is what I use for everything else.
It sometimes sells in a bundle with a bag and the plunge base.
-- Clin
View TechTeacher04's profile
TechTeacher04
447 posts in 2336 days
#13 posted 03-24-2020 06:34 PM
+1 for the DWP611, I also have the DCW600B. They share a common motor diameter, the bases including the plunge and fixed bases are interchangeable.
bronxtale
#14 posted 03-24-2020 07:55 PM
- JackDuren
Same type of wood to make handles etc…
Nothing fancy over here.
bronxtale
#15 posted 03-24-2020 08:00 PM
- JackDuren
- bronxtale
Was comparing the Makita RF1101 vs the Trim Router Kit.
