Shop Vac - One minor irritation relieved
Forum topic by BlasterStumps posted 03-22-2020 08:34 PM 267 views 0 times favorited 1 reply Add to Favorites Watch
View BlasterStumps's profile
BlasterStumps
1688 posts in 1216 days
03-22-2020 08:34 PM
The wide floor attachment I use with my shop vac kept sticking to the floor when I was trying to vacuum. Couple that with having to bend over to vacuum because the wand was too short, it was getting very irritating. There are several ways to address this problem but here is my fix:
I decided to modify the foot by heating it on both sides and pushing a piece of 1-1/2” pvc into it. That produced the slight U-shaped ends you can see in the picture. Still picks up stuff fine but no more sticking to the floor.
I also heated up a piece of 2” PVC and made a slight bend in it, then heated the ends and made them work with my vacuum pipes. One end goes over and the other goes in. This gives me enough of a different angle and extra length for the wand so now I can stand upright to vacuum. It helps.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
1 reply so far
View Kelly's profile
Kelly
3014 posts in 3721 days
#1 posted 03-22-2020 09:02 PM
One of mine came with notches for that very reason. A solution so over due.
