Top Coat
Forum topic by 67flh posted 03-09-2020 12:02 AM 390 views 0 times favorited 6 replies Add to Favorites Watch
View 67flh's profile
67flh
117 posts in 2521 days
03-09-2020 12:02 AM
I am building a quilt rack out of Red Oak. I am going to stain it with a neutral color Gel Stain. This piece will never be subjected to the elements. Would it be ok if I just paste waxed it and called it good or should I put a coat of Polyurethane on it to boot?
-- Brad
View LesB's profile
LesB
3092 posts in 4682 days
#1 posted 03-09-2020 12:38 AM
Wax will work. The only disadvantage is if it gets dirty over time it will be a bit harder to clean.
I think I would use a coat or two of wipe on poly. Not enough to build a heavy top coat but enough to seal it.
-- Les B, Oregon
View tvrgeek's profile
tvrgeek
2281 posts in 2889 days
#2 posted 03-09-2020 01:01 AM
As long as it does not get constant hand oils, and it likely would not, I would do a couple coats of oil and then eventually wax. I love how the colors come out over time and it gains depth with oil and wax. It would need to cure quite a while to be fully crystalized before hanging a quilt on it. Poly would not have that issue and it would not need maintenance every year or two.
Red oak is such a pain to get sealed up with poly. Doing a coffee table as we speak.
67flh
#3 posted 03-09-2020 02:57 PM
Thanks for the replies, I have never used wipe on poly, may look into it. I too love how oak ages.
-- Brad
View LittleShaver's profile
LittleShaver
777 posts in 1859 days
#4 posted 03-09-2020 03:08 PM
Neutral stain seems odd to me.
My wipe on poly mix is 50/50 poly/Mineral Spirits. Takes about 3 coats of wipe on to equal one of straight poly, but it is easier to apply and dries faster.
Leave the quilt off the rack for a week or two to let the poly fully cure. If you rush this step, you run the risk of the fabric and the poly becoming one.
-- Sawdust Maker
View LesB's profile
LesB
#5 posted 03-09-2020 06:01 PM
- tvrgeek
Red oak has a lot of open pores so on smooth surfaces like table tops I usually use a grain filler first. Trying to fill the grain with poly is a problem.
-- Les B, Oregon
67flh
#6 posted 03-09-2020 11:25 PM
Poor choice of words should have said pecan, I like the lighter colors cause it lets the grain come stand out. Do you do the mix yourself or does it come that way?
- LittleShaver
-- Brad
