Forum topic by Tony Ennis | posted 03-08-2020 06:21 PM | 461 views | 0 times favorited | 4 replies | ![]() |
Topic tags/keywords: draw knife drawknife I was making some chicken roost bars from 2×2s. Wife wanted the splintery bits removed. I got a spokeshave from a friend some time back and couldn’t think of a better time to use it. It worked ok but needed sharpening. I found it was too hard to be marked by a file. Is this expected? -- Tony |
#1 posted 03-08-2020 06:45 PM |
Yes , you need a oil stone or a Water stone or a diamond stone in the 2000 to 8000 range. Heard of some folks using sand paper but never seen or even considered trying it:) Suppose if the blade is not to bad could strop it with some compound, but if you took a file to it way too late? A spoke shave blade should be able to shave the hair off your arm! -- Lifting one end of the plank. |
#2 posted 03-08-2020 09:01 PM |
Sharpen first. Then, don’t forget that draw knives can be used bevel up or down depending in the cut(s) required. Angled blades cut a bit better, so don’t forget that. Makes for slicing motion. Make sure that grain direction is in your favor. Trying to cut on rising grain is a no-no. Leads to tear out. |
#3 posted 03-08-2020 10:07 PM |
It depends on your file but, most likely. If a file marked it, it would likely be too soft to hold an edge. Just at a guess, I’d say anything you marked with a typical file would be <50-55 Rc. For a blade, you want to be upwards of that around 60 Rc. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#4 posted 03-10-2020 05:03 AM |
During the past 18 years of raising chickens, not once has a chicken complained about splinters. If a bird decided to have an attitude, he just simmered a bit with some wine and vegetables. Delightfully good! Or slow roast. |
Forum | Topics |
Woodworking Skill Share
13203 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1898 |
Finishing
6348 |
7910 |
32777 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1806 |
Wood & Lumber
7282 |
1634 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9662 |
