How would you design a 7 foot window cornice
Forum topic by Oldtool posted 03-01-2020 09:31 PM 382 views 0 times favorited 3 replies Add to Favorites Watch
View Oldtool's profile
Oldtool
3354 posts in 3480 days
03-01-2020 09:31 PM
Topic tags/keywords: question oak design tip
I’ve been asked to make two window cornices, each 7 foot long, and to be made from oak. I’ve secured the wood, and a cornice isn’t very hard to make, but there is one concern I can’t seem to rectify in my mind, that being:
The length of a 7 food oak board, 3/4 ” X 5.5” (it’s a standard 1 X 6), will weigh close to 8.5 lbs.
I’m tossing the following around in my head as concerns to be addressed in order to do this correctly, without it falling off the wall;
- Should I incorporate a top, as I was going to simply use a open U shape to reduce weight?
- I believe I should mill the front board to 1/2” thickness, and leave the sides at 3/4”?
- I’m thinking a center bracket will be necessary, for both weight support & maintaining a flat appearance without drooping or bowing out.?
Maybe I’m over thinking this, but would greatly appreciate any thoughts or suggestions anyone my have.
Thanks,
Tom
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
3 replies so far
View recycle1943's profile
recycle1943
5978 posts in 2912 days
#1 posted 03-01-2020 09:39 PM
If I put that up in my house, it would have a middle support. I don’t know if it needs it or not but it would be there
-- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them
View Tony_S's profile
Tony_S
1547 posts in 4372 days
#2 posted 03-01-2020 10:44 PM
Yes, you’re over thinking it. Incorporate a top and hang it with a full length french cleat.
-- Lj's...The place to post what you had for breakfast and then do your utter best to complicate the hell out of the simplest of questions.
Oldtool
#3 posted 03-01-2020 10:50 PM
Tony S, you’re right, that’s the simplest and mom most secure solution, and it’ll fulfill recycle1943’s suggestion of the center support.
Thanks guys, lately my brain has been in a fog.
