Forum topic by Bill Berklich | posted 02-29-2020 06:11 PM | 965 views | 0 times favorited | 6 replies | ![]() |
Topic tags/keywords: question wagon vise cross dowel workbench vise Ok – knew it would happen eventually. Screwed into Pine end grain and while workign on the Mallet Swap I reefed down a bit too much and jacked the screw out. Besides the peg and glue the holes or drill and insert hardwood cross dowels are there any other ways to reinstall/strengthen these? -- Bill - Rochester MI |
#1 posted 02-29-2020 06:40 PM |
You could reinstall by just rotating your collar 90 degrees. Personally, I’d either drill up from the bottom and insert barrel nuts and use machine screws or find the longest lag bolts I could that weren’t too big for the holes. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#2 posted 02-29-2020 09:08 PM |
Kenny – thanks. I was over focused on using the hardware it came with. I reinstalled with 3” long 1/4” lags. It’s never coming out now ;-) -- Bill - Rochester MI |
#3 posted 02-29-2020 09:14 PM |
A couple of suggestions.. Hardwood cross dowels. Run CA glue down the current holes using thin glue. Drill out holes an insert hardwood plugs. |
#4 posted 03-01-2020 10:07 PM |
#5 posted 03-02-2020 09:09 AM |
- another option but more difficult to retrofit would have been making a larger hole where the screw passes and insert the nut in it from the other side in such a way that there would be no traction on the screws (except when un-tightening) -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn |
#6 posted 03-02-2020 01:28 PM |
Excellent :-) Even in end grain, a nice long lag bolt (properly pilot drilled) has a lot of holding power. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
Forum | Topics |
Woodworking Skill Share
13247 |
Woodturning
2831 |
Woodcarving
579 |
Scrollsawing
417 |
Joinery
1914 |
Finishing
6403 |
7945 |
32957 |
CNC Woodworking
335 |
Hand Tools
6489 |
Jigs & Fixtures
1825 |
Wood & Lumber
7312 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5437 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
