For Sale. Delta Unisaw Mobile Base $150
Forum topic by rkruz posted 02-26-2020 09:36 PM 179 views 0 times favorited 2 replies Add to Favorites Watch
View rkruz's profile
rkruz
49 posts in 55 days
02-26-2020 09:36 PM
$150
Used mobile base designed for Delta Unisaws with 52-Inch Biesemeyer fence system.
Delta PN 50-257 Type 1.
Perfect working condition.
It came with my saw but I have a fixed installation and dont need the mobility. However it did come in handy when we first positioned the saw. Using the mobile base the 650 lb saw was very easy to use and move around.
$332 New.
Pick up in Orange County CA.
2 replies so far
View MrUnix's profile
MrUnix
7809 posts in 2870 days
#1 posted 02-26-2020 10:01 PM
It should be noted that base is for the newer Unisaw which has a slightly larger footprint than the older models. The older models use a different base (50-273 for the saw itself). I would love to know if the newer style base would work with the older models, so if anyone knows, please speak up!
rkruz
49 posts in 55 days
#2 posted 02-27-2020 01:03 AM
I dont know either if it fits older generation saws but here are the measurements of the mobile base.
The inside measurements of the recess where the saw sits is 28.25”w x 23.5” d and each corner has a triangle shelf 5” on a side. I hope that info can be of some use. Thanks!
