Forum topic by JackDuren | posted 02-25-2020 08:28 PM | 305 views | 0 times favorited | 6 replies | ![]() |
Bought blades off Ebay maybe 10-15 years ago.I called Delta support and he didn’t suggest them as they were 7/7 rather than the 1” blades they sell for the planer… Anybody used anything less than 1” before?.... |
#1 posted 02-25-2020 08:28 PM |
Sorry 7/8 blades… |
#2 posted 02-25-2020 08:49 PM |
Those knives can be sharpened over and over again until they are too short to be safe… I would think that a 1/4” or more could be removed with them still being fine – it should be obvious when they aren’t. General rule is that the locking screws for the lock bar be firmly over the knives. Once the edge of the knife reaches past that point, then they are too short to be safely used. The manual does not specify a minimum width unfortunately. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#3 posted 02-25-2020 09:04 PM |
I keep thinking if they ground off 1/8 sharpening over time it would be the same. |
#4 posted 02-25-2020 09:09 PM |
The blades are dull and I may have a cabinet job coming up so I thought if I have to pull them I’d try the others. They charge by the inch to sharpen, so I’ve been delaying it…thks… |
#5 posted 02-25-2020 09:19 PM |
They charge by the inch to sharpen, so I’ve been delaying it…thks… Same here… $1 an inch… and you can get new knives for not much more – about $40 for my Makita. But I think you will be fine… 1/8” is not a lot and would be the same as stock knives that have been sharpened multiple times. Either way, it’s always good to have a spare set on hand so you don’t have any down time – which usually happens at the worst possible moment :) Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#6 posted 02-27-2020 08:13 PM |
Pulled and replaced today. I had never pulled the tape off the new blades but they did say Delta. Thx… |
Forum | Topics |
Woodworking Skill Share
13209 |
Woodturning
2816 |
Woodcarving
570 |
Scrollsawing
416 |
Joinery
1903 |
Finishing
6356 |
7915 |
32796 |
CNC Woodworking
331 |
Hand Tools
6459 |
Jigs & Fixtures
1809 |
Wood & Lumber
7285 |
1634 |
Focus on the Workspace
2637 |
1273 |
Woodworking Trade & Swap
5421 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9664 |
