Drill Press Quill Travel - How much do you *really* need??
Forum topic by PresidentsDad posted 02-20-2020 04:49 PM 2831 views 0 times favorited 22 replies Add to Favorites Watch
View PresidentsDad's profile
PresidentsDad
147 posts in 1304 days
02-20-2020 04:49 PM
Hey all,
I have use of a Delta 12 inch drill press currently that has about 2.5” of quill travel, but I have to get it back to my father. So…I’m in the market for a reliable, but inexpensive drill press and I have narrowed my choices down to two WEN products. The 4214 (12 inch bench model) or the 4225 (15 inch floor model). The only real difference between these other than the more powerful motor, extra room to drill and lower rpm speeds is that the quill travel on the 12 inch model is about 3-1/8” and the 15 inch model is a full 4” of travel.
Question for the group. How often do you need to drill a hole deeper than 3-1/8”? Is the extra 7/8” really worth it?
Thanks in advance.
22 replies so far
View John Jardin's profile
John Jardin
98 posts in 696 days
#1 posted 02-20-2020 05:01 PM
Get the 15” floor model…quil travel is irrelevant
View tvrgeek's profile
tvrgeek
1769 posts in 2705 days
#2 posted 02-20-2020 05:16 PM
I have to disagree with half of that statement. My benchtop Craftsman has 2 1/2 inches and it drives me crazy. I wanted over 4, but settled on a used Delta 16 1/2 inch floor with 3 1/8. I have a document listing about every current 15 and 17 incher out there and basic specs. Had I not bought the Delta, I was going to get the 17 inch Palmgren. Rikon VS was second. Jet JDP 17 sure was nice, but both stores floor model had the depth adjustment not working correctly. Powermatic and Nova were flat too expensive.
Look carefully. Some do not go slow enough for big woodworking bits ( 600 RPM slowest on some) some not fast enough for small metal bits ( 2200 on some) . 3 1/8 stroke seems common on “cheaper” drills, 4 and 5 on slightly better. Some drills have tiny round tables or small T-slot better suited for metalwork. I settled on the 3 1/8 stroke as the old Delta had almost everything I wanted and I could pay for it. It is a HUGE step up. Not perfect, but I don’t live in Perfectville.
I would have liked a larger table. I woudl have liked a full 90 degree to the side tilt for drilling ends of longer stock, I would have liked Reeves drive, I would have liked 1 HP. Oh well, I would have liked to win the lottery too.
The thing that gives me confidence, is with the quill fully extended, I can barely feel the slightest of play. Just purrs running and it needs new belts. Go test a Horrible Freight. You measure the slop in mm. Many mm. Look at the pulleys. Rougher than sandpaper.
View xeddog's profile
xeddog
336 posts in 4063 days
#3 posted 02-20-2020 05:22 PM
I had a Craftsman floor standing drill press with 3” quill travel for a long time. Then I replaced it with the new Delta, and I gotta say I REALLY like having 6” quill travel. Raising or lowering the table is almost a thing of the past now. Do I NEED 6” travel?? No. But it is NNNIIIIIIIIIce.
Wayne
View CaptainKlutz's profile (online now)
CaptainKlutz
4352 posts in 2550 days
#4 posted 02-20-2020 05:34 PM
My 2 cents:
Considering that standard drill bits only provide ~3” of chip clearance depth; quill travel beyond 3-1/8” is strictly for user convenience to reduce table height adjustments.
Be sure to check quill tolerances when considering 6” depth machines. Have to be spend extra on a premium tool to get short throw tolerance with longer throw. Drilling wood you may not care about larger tolerance, but metal workers will see/feel the difference at max extension. BTDTGTTS
YMMV
View Andre's profile
Andre
4460 posts in 2862 days
#5 posted 02-20-2020 05:40 PM
Simple answer, somewhat! you always need just another 1/4” :)
View ChefHDAN's profile
ChefHDAN
1803 posts in 3906 days
#6 posted 02-20-2020 07:39 PM
I had the 9” Ryobi for many years, and can’t say I actually remember how much travel the quill had. It was doing most everything I needed, and then one day in Lowes I see a Hitatchi B16RM display floor on clearance for $100. It was like night & day having the capacity to the table. My advice would be that if you have the floor space, go with the bigger model, it’s super annoying to think you’ll put a hole in something and suddenly with the drill bit was shorter.
View therealSteveN's profile
therealSteveN
7498 posts in 1630 days
#7 posted 02-20-2020 08:20 PM
If I could get 12” quill travel, I’d pay extra for it. My current DP has 4” of travel, and I often find myself debating if I will just use a hand drill, instead of mousing around with table height adjustment to just drill some stinking holes.
I view adjusting your table height to just drill a hole, a failure of the product you are using. You spend a while setting the fence just right, as soon as that table moves, well, there went that set up time. It’s not just lifting the table up and down.
Quill travel is my #1 criteria of a good drill press, everything else can be wiggled out. It’s a matter of fact the “better” drill presses are the ones with a longer quill travel, so those better tools will also be more accurate, have greater motor capacity, finer adjustment, and a whole slew of features your POS 2” travel junk presses will not have. At some point in the cheap scale, just using a hand drill is a very real comparison.
Inherently in all woodshop equipment the design of the tool puts in features meant to create accuracy, fences on TS, Jointers. 4 posts for equal height adjustment on planers. All but the drill press, cheaply made ones have no accuracy, you need to pay for it, and quill travel is going to be there when you arrive. You can adjust a POS cheap TS to make a good cut, it may not stay adjusted, but you can get there. On a cheap DP, you just can’t make something spinning around like a drunk, go straight, and until you get straight it’s junk.
I’ll admit to being a hole snob, thank you very much. Actually those holes generally define if the piece is well made or not. Haphazard hole placement is death in any other trade, yet many woodworkers try to limp past it. At the same time the tools they say are for woodworking are often the worst tools woodworkers own. In all of the answers an accurate, and YES more expensive tool is what can fix that problem.
Yeah I know life sux.
-- Think safe, be safe
View bruce47's profile
bruce47
29 posts in 3638 days
#8 posted 02-20-2020 08:27 PM
tvrgeek was talking about spindle speeds. What I am giving some real serious thought to was changing out the motor. I have a 2hp DC motor from a tread mill that I am thinking about using. It is controlled by a rheostat that came with it. I slowed it down pretty slow, put some gloves on and tried to stop it. That was not going to happen, that little motor just put more juice to it and I don’t think I slowed it down at all. Something to think about for slow speeds or fast speeds.
tvrgeek
#9 posted 02-20-2020 09:06 PM
Bruce, may be a great tip where to find a motor and controller cheap. Lots of treadmills out there where the only exercise they provide is moving it across the basement. A 1.75 HP DVR with controller runs about $650
Got my Delta set up. Somehow I have more space now.
Captain, No “standard” chip clearance depth. Jobber length depend on diameter. Stub bits only about 1/2 inch. Forstner, Spur, spade, and any length you want. Sure, once about three inches one has to do extra effort to clear the chips, Wood or metal. I decided I woudl continue to finish deep holes by hand and save me a grand. At least for now.
Andre, won’t touch that!
I suspect within a few years DVR motors will be far more common.
View Madmark2's profile
Madmark2
2512 posts in 1644 days
#10 posted 02-20-2020 09:28 PM
I make pipes. Lack of quill travel means I have to hand power drill the 2nd half of the stems with a 12” bit. 6” of quill travel would eliminate the hand drilling – which is where most of the drilling failures occur. A longer stroke drill press would be a godsend in my little shop.
My pipes for sale at Smokin’ Knight
-- The hump with the stump and the pump!
View HokieKen's profile
HokieKen
17318 posts in 2195 days
#11 posted 02-20-2020 09:53 PM
It’s not so much a matter of how deep you drill holes IMO but being able to use drills of multiple lengths without messing with the location of your part. So, I may want to start out with a center drill that’s 2” long, then put in a 5/16 drill that’s 4” long then put a 2” long tap in the head to get it started dead true and square. So, I’ve eaten up 2” of quill travel just ensuring that I can put all 3 bits in without having to change table height.
I know you’re thinking that’s just for metal work and I don’t do any of that. Well, what about when you need to drill a clearance hole through a 8/4 thick board with a 4” long drill bit then put a 82 degree countersink on it?
Basically, you’ll never regret spending a bit extra for extra quill travel IMHO :-)
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View Redoak49's profile
Redoak49
5186 posts in 3045 days
#12 posted 02-20-2020 11:06 PM
My DP has 6” quill travel and variable speed 50-3000 (and can go higher). The run out is very low and smooth running.
Yes, the Nova Voyager DVR is expensive but I love to use it. I think they have gone up in price a couple hundred since I bought mine.
View pottz's profile
pottz
16218 posts in 2040 days
#13 posted 02-20-2020 11:15 PM
my answer a lot.ive got the delta woodworkers drill press that has 6” and sometimes even thats not enough so id say the more the better.3-1/8” would be on craigs list-lol.
View SMP's profile
SMP
3817 posts in 962 days
#14 posted 02-21-2020 12:29 AM
- Andre
Basically this. However, once a hole is 2” in, you can finish it by hand perfectly straight, even after a few beers.
tvrgeek
#15 posted 02-21-2020 12:54 AM
Simple math:
2 1/2 inch, $120 years ago. Drove me crazy but suffered with it for close to 30 years thankful I had a drill press at all.
3 1/8, $350 for a quality used tool. Far better. Not even an inch more, but makes a big difference.
6 inch for a super tool. Fine, want to spot me the other $1300 bucks? Buying a new band saw with it instead
I sent contact forms to several companies from whom I had asked for details and described some of the features they got wrong. Stroke is one. Another is table design. They could offer an option ( or second one for a small fortune) between a large open X slot and a fluid type T-slot. Many have lots of speeds, but the range is too small. 16 speeds they should be able to get from 150 to 3000 and production cost would not be any higher. If you need more precision that that, you should be using a mill. Not sure why so many are so short. 6 inches more post would be handy. Designed by five foot Chinese guys? I just set mine on a 4 inch platform so the work is high enough for me to see it. If more folks provided helpful feedback, it might help the future market. Longer stroke is not expensive either. Add an inch and a half to the spindle. Most would still fit inside the existing top covers! Fractions of a cent in production cost. Add 3 and it means a higher piece of molded plastic for the top. Once tooled, no real cost.
