How do I make this? A three piece corbel painted on the outside and stained on the inside.
Forum topic by RickDel posted 02-20-2020 05:26 AM 1206 views 0 times favorited 14 replies Add to Favorites Watch
View RickDel's profile
RickDel
58 posts in 1004 days
02-20-2020 05:26 AM
Hello, I’m looking for advice on finishing some corbels like the ones pictured below. I know I can’t glue painted or stained wood, so how do I complete this? What’s the steps? Thanks
14 replies so far
View John Smith's profile
John Smith
2993 posts in 1372 days
#1 posted 02-20-2020 01:36 PM
are you wanting to have the two sides painted white
and the middle stained wood ??
(how many are you going to make).
I would stain just the show sides of the center piece
and paint only the show sides of the outside pieces
leaving enough raw wood in the middle for the glue lines.
-- I am a painter: that's what I do, I like to paint things. --
View SMP's profile
SMP
4692 posts in 1115 days
#2 posted 02-20-2020 01:37 PM
Why can’t you glue it? I guess i’m not understanding something.
View Phil32's profile
Phil32
1553 posts in 1112 days
#3 posted 02-20-2020 04:35 PM
- SMP
Because most stains and paints seal the wood, preventing the glue penetration necessary for a good joint.
-- You know, this site doesn't require woodworking skills, but you should know how to write.
View sras's profile
sras
6313 posts in 4338 days
#4 posted 02-20-2020 05:08 PM
What John said.
View CaptainKlutz's profile
CaptainKlutz
4854 posts in 2703 days
#5 posted 02-20-2020 05:23 PM
Easy.
Sand both contact surfaces with 40-60grit, exposing the wood; and use what ever glue you want.
Mask the inside exposed edges on outside corbel before sanding.
The large grit will leave enough surface area that almost any adhesive can form a strong bond, even with little paint/stain left behind.
If plan is outdoor use, the a slow cure epoxy would be my adhesive of choice.
Plus if you get a little squeeze out, the clear epoxy will be less noticeable.
YMMV
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
RickDel
#6 posted 02-21-2020 02:16 AM
Thanks for the replies…
“are you wanting to have the two sides painted white
leaving enough raw wood in the middle for the glue lines.”
John, Yes, two outsides painted and inside stained (same as shelf). I’m making four sets. Thanks for your suggestions.
“Easy.
Plus if you get a little squeeze out, the clear epoxy will be less noticeable.”
CaptainKlutz, Thanks!
View SMP's profile
SMP
#7 posted 02-21-2020 02:21 AM
- SMP
- Phil32
Big box stores literally have aisles full of various glues and adhesives that will stick to stick to paint and stain no problem. Especially something decorative like a corbel. I mean sure, if I was going to stand on it i might buy a $3 tube of 5-minute epoxy but would have no problem putting my full weight on it.
MrUnix
8744 posts in 3408 days
#8 posted 02-21-2020 05:46 AM
If you are concerned about the glue not holding long term… just glue them up, then drill a few holes through the pieces (through all three pieces) and glue in some dowels. Cut/sand flush to the outside then re-paint where the dowel ends are left exposed.
View Kazooman's profile
Kazooman
1540 posts in 3161 days
#9 posted 02-21-2020 01:37 PM
I agree with those who are not worried about the glue holding given the manner in which the corbels will be used. If you are concerned enough to go with Brad’s dowel system you can plan ahead and drill the holes before the glue up and leave the holes in the painted pieces blind. Use dowel centering pins to do the alignment. Personally, I wouldn’t bother.
Nice looking corbels, by the way. I seem to recall your question about marking a pattern. It looks like you nailed it.
View Tony1212's profile
Tony1212
580 posts in 2944 days
#10 posted 02-21-2020 01:53 PM
I can’t tell in the picture, but it looks like the white sides have scroll saw cuts that would (theoretically) show the stained wood through the holes. So sanding the sides for glue might not work.
But since the sides are painted, you can drill holes in them for screws and cover the screw heads with wood filler and repaint.
-- Tony, SW Chicago Suburbs
View bondogaposis's profile
bondogaposis
6024 posts in 3560 days
#11 posted 02-21-2020 02:11 PM
If you use a water or alcohol base dye instead of stain you can glue it without detriment.
-- Bondo Gaposis
RickDel
#12 posted 02-21-2020 06:05 PM
SMP, I guess I was fixated on “wood glue” and never considered a non-wood glue adhesive over paint / stain.
Bondo Gaposis, thanks. I didn’t know dyes could be used with wood glue.
Kazooman, thanks for the dowel idea.
“I can’t tell in the picture, but it looks like the white sides have scroll saw cuts that would (theoretically) show the stained wood through the holes”
YES!! It looks like the entire outside pieces are painted and the inside piece is stained. I couldn’t see how this could be done with wood glue.
Thanks for all the responses. I think I’ll just try to leave a small portion of exposed surface for wood gluing. I wasn’t sure that would work, but I’m going to try it.
View SMP's profile
SMP
#13 posted 02-21-2020 06:23 PM
- RickDel
I pretty much keep a bottle of CA glue and a syringe of 5 minute epoxy in my top toolbox drawer at all times and treat them like “tools”. Epoxy will stick just about anything together and fill gaps etc. I use wood glue too where it makes the most sense, and have 3 or 4 types of titebond on hand. Just use the “best tool for the job” instead of forcing a square peg through a round hole.
View Kelly's profile
Kelly
3751 posts in 4153 days
#14 posted 02-22-2020 04:45 AM
Like SMP, I have more than one glue. I have CA (commercial versions), over a gallon of epoxy, the usual Titebond, hyde, contact, powdered marine…. In short, where there’s a need, there’s a glue.
