Needing source for metal wye 8" x 8"x 4"
Forum topic by OLCHIEF posted 02-18-2020 10:59 PM 338 views 0 times favorited 9 replies Add to Favorites Watch
View OLCHIEF's profile
OLCHIEF
31 posts in 111 days
02-18-2020 10:59 PM
I am using 8” metal duct in the main line to the dust collector and 4” flexible hose from the machines to the main line. I am looking for a source of 8” x 8” x 4” angled wyes not much luck at any of the local stores
-- OL CHIEF, Florida Panhandle
9 replies so far
View Sawdust35's profile
Sawdust35
77 posts in 1592 days
#1 posted 02-18-2020 11:18 PM
View ibewjon's profile
ibewjon
1507 posts in 3523 days
#2 posted 02-19-2020 12:13 AM
Or you can make your own with a spot welder from harbor freight and some 26 guage steel duct. Then seal with paint in duct sealer. 5” x 5” x 4” tap y.
View fivecodys's profile
fivecodys
1610 posts in 2366 days
#3 posted 02-19-2020 12:28 AM
You might check with KenCraft as well: https://www.kencraftcompany.com/products/dust-collector-fittings-2/
-- A bad day woodworking is still better than a good day working.
View Samdog's profile
Samdog
8 posts in 2794 days
#4 posted 02-19-2020 01:01 AM
Try your local HVAC supply house. If they dont have a 8×8x4 . They wiill likely have a 8×8x8 and a 8×4 reducer.
View therealSteveN's profile
therealSteveN
5545 posts in 1304 days
#5 posted 02-19-2020 01:15 AM
- Samdog
Often overlooked. Sometimes in stock, but most of the bigger places have at least a guy who can fabricate if not a few guys, and for the most part much cheaper per item than what I see posted on here from “Dust Colllection suppliers” who I believe operate at about 700% over cost.
-- Think safe, be safe
OLCHIEF
#6 posted 02-20-2020 02:04 AM
Thanks you all for the information. I now have a direction
OLCHIEF
#7 posted 04-05-2020 01:06 AM
I got my 6 wyes from The Sheet Metal Kid. They are well made and arrived quickly and undamaged.
View waho6o9's profile
waho6o9
8876 posts in 3306 days
#8 posted 04-05-2020 01:22 AM
Try a sheet metal place easy peasy.
View Jim Finn's profile
Jim Finn
2826 posts in 3651 days
#9 posted 04-06-2020 01:42 AM
They are pretty easy to make even without a spot welder. Just cut the needed hole (egg shaped) in the 8” duct and then insert the 4” duct, mark the meeting point and cut the 4” piece to that mark and make 1/2” tabs all around t the place where the two meet. Bend Every other one inside and outside. Then seal with duct sealer as shown in the sawdust 35 post post. I have made all the wyes I needed for my 6” metal system.
-- No PHD just a DD214 Lubbock Texas
