Workbench pipe clamp -which design is better?
Forum topic by MiniMe posted 02-18-2020 05:03 PM 331 views 0 times favorited 6 replies Add to Favorites Watch
View MiniMe's profile
MiniMe
389 posts in 735 days
02-18-2020 05:03 PM
I have two possible designs for this, both shown below
The second design required just two pipes which I can use for other purposes as well
This is also related to my project workbench featuring an adjustable height segment that can be used as outfeed from my table saw (see the second picture)
View Andybb's profile
Andybb
2647 posts in 1287 days
#1 posted 02-18-2020 05:42 PM
If you have the clamps build both and see which one works best for you. The second one looks simpler to use whereas the first one seems to be more versatile.
-- Andy - Seattle USA
View WoodenDreams's profile
WoodenDreams
977 posts in 595 days
#2 posted 02-18-2020 05:45 PM
personal preference. I like the four clamp set-up.
View LesB's profile
LesB
2426 posts in 4127 days
#3 posted 02-18-2020 05:49 PM
Inovative idea but I think the pipe clamp handles sticking out will be inconvenient at best.
I designed a similar work table that you might consider. The one improvement I haven’t made is to install a scissor jack to make raising the lowering the top easier. It has worked quite well and the interior provides much needed storage area. Attached is a Sketchup pict and a CAD drawing of it.
-- Les B, Oregon
MiniMe
#4 posted 02-18-2020 06:37 PM
I designed a similar work table that you might consider. The one improvement I haven t made is to install a scissor jack to make raising the lowering the top easier. It has worked quite well and the interior provides much needed storage area. Attached is a Sketchup pict and a CAD drawing of it.
- LesB
I considered scissor jacks too but it is an overkill in my case, this simplified design (with hinges between the verticals and the horizontal of the outfeed) allows me to handle an uneven raising of the two sides of the outfeed table
Besides that the above design is much simpler to build (the table is already done)
MiniMe
#5 posted 02-18-2020 06:42 PM
The two designs are not identical at all. #2 saves on clamps and clamp bars at the cost of putting a higher pressure on the structure of the table more exactly it squeezes the two pieces of 2×4 parallel with the bars of the clamps
The first design will use dedicated bars which can’t be used for anything else after this
I have 3 of the 4 clamps and I am inclined and three pipes already
I am inclined to build the first design and if not happy I will revert to the second one to see how it goes
Either way I have to drill 4 holes so that is not an issue
Second design requires you to have the table at the desired level on both sides as the tightening will affect both sides
View bmerrill's profile
bmerrill
89 posts in 757 days
#6 posted 02-18-2020 09:34 PM
Version #1.
-- "Do. Or do not. There is no try". Yoda
