Craftsman Jointer 6” model 10323900 parts
Forum topic by CoyoteOne posted 02-18-2020 01:18 PM 200 views 0 times favorited 2 replies Add to Favorites Watch
View CoyoteOne's profile
CoyoteOne
1 post in 141 days
02-18-2020 01:18 PM
Topic tags/keywords: craftsman jointer jointer blade
I bought this jointer and while restoring it I found that it was missing the cutter blade wedges. Do any of you pros know a good place to pick some up? I’ve tried eBay, and have done some basic internet research. I figured someone on here might know a place to get some or at least know what I could substitute in their place.
Thanks!
2 replies so far
View controlfreak's profile
controlfreak
755 posts in 373 days
#1 posted 02-18-2020 01:59 PM
I think I have that model I bought for $150. I did some derusting and installed new blades and power switch. It is odd to be missing those wedges because the only reason to remove them is during a blade change. Someone must have removed the blades to explore replacing and lost interest. I did a quick search but no luck. I would keep your eye open for a badly rusted Craftsman with the same cutter head or determine who the actual manufacturer is and work that angle. Sorry not much help.
View Aj2's profile
Aj2
3078 posts in 2569 days
#2 posted 02-18-2020 02:59 PM
I believe that’s a craftsman jointer with a fixed outfeed table. It’s not a good jointer to spend anymore money on.
The reason the knife gibs could be missing is they flew out with the machine running.
I had one of those jointers for years before the internet.
The gibs screw down into the bottom of the knife slots a very bad design.
Look for a jointers with a handwheel on the outfeed same as the infeed.
Good luck
-- Aj
