Planing short pieces
Forum topic by dbw posted 02-16-2020 07:48 PM 763 views 0 times favorited 31 replies Add to Favorites Watch
View dbw's profile
dbw
377 posts in 2308 days
02-16-2020 07:48 PM
Topic tags/keywords: planing short stock planer bed
I need to plane pieces of stock which are less than 5” long. I’m planning on hot glueing them to my planer sled, which has a cleat at the end. Is this a good idea or a recipe for disaster?
-- measure 3 times, cut once
31 replies so far
View tvrgeek's profile
tvrgeek
547 posts in 2320 days
#1 posted 02-16-2020 08:50 PM
5 inch piece but a couple of inches on each end for snipe, so looking for a one inch board? Too wide to use the jointer?
View dbw's profile
dbw
#2 posted 02-16-2020 08:59 PM
The pieces are 4.5” X 3”. These are cast-offs from another project. I’m resawing them from 6/4 because I need +/- 1 1/16” thick.
View ibewjon's profile
ibewjon
1361 posts in 3464 days
#3 posted 02-16-2020 09:17 PM
Butt the pieces end to end on the sled.
View MrUnix's profile
MrUnix
7809 posts in 2870 days
#4 posted 02-16-2020 09:29 PM
Which planer do you have? Not all are the same… My Makita can do as short as 5.5” (with no snipe!), but my Ridgid states a 12” minimum. Anyway, you should be fine hot gluing or double sided taping them end to end on a backer board and running it through.
View dbw's profile
dbw
#5 posted 02-16-2020 10:34 PM
DeWalt 735. Which Makita do you have?
MrUnix
#6 posted 02-16-2020 10:43 PM
- dbw
2030 planer/jointer combo
View realcowtown_eric's profile
realcowtown_eric
631 posts in 2608 days
#7 posted 02-17-2020 01:07 AM
just mount your jointer plane in the shop-vice upside down and do it manually.
That trick has been in tips and technique books for a half century
Eric
-- Real_cowtown_eric
View bandit571's profile
bandit571
24965 posts in 3354 days
#8 posted 02-17-2020 01:31 AM
Hmmm…
This one is 4-1/2” long….
Which is the ends on this box….6” combo square is for scale….
View cmacnaughton's profile
cmacnaughton
177 posts in 315 days
#9 posted 02-17-2020 01:37 AM
- bandit571
Yep…nice and quiet, too!
-- –Chuck M. Nutmegger by choice
View Jeff's profile
Jeff
21 posts in 56 days
#10 posted 02-17-2020 05:41 AM
I concur with bandit571, a #3 or #4 bench plane will also be quicker than the time it takes to set up a sled.
View Andre's profile
Andre
3194 posts in 2477 days
#11 posted 02-17-2020 07:16 AM
Place sacrificially strips of wood down either side.
View pintodeluxe's profile
pintodeluxe
6080 posts in 3484 days
#12 posted 02-17-2020 07:46 AM
A melamine sled can be used over and over again, so it’s a useful addition to the shop.
My 735 can probably handle pieces that short, but I use a Shelix head.
A flat, continuous surface is a must. It can be a sled that gets pulled through your planer, or a stationary piece of melamine with cleats underneath.
If you want to temporarily attach short lengths of wood to a planer sled, try double sided carpet tape.
You just have to ask yourself if the potential yield is worth the risk to your equipment and livelihood.
View LittleBlackDuck's profile
LittleBlackDuck
3790 posts in 1492 days
#13 posted 02-17-2020 09:49 AM
Personally it might be more economical to turf the 5” scraps… after all they are scraps that potentially generate opportunities for an accident and replace by newly cut, longer, manageable pieces without the risk.
You’ll probably find you’ll save a fortune by not piss farting about trying to formulate a futile workaround.
View Robert's profile
Robert
3655 posts in 2152 days
#14 posted 02-17-2020 02:43 PM
Depends on how far apart the roller and cutter head as well as the type of cutter (knives vs helical).
I can tell you for a fact, ds tape, hot melt glue, sled or not, when you hear the explosion its too late to think about whether you’ve got more lumber :-D
Best to thickness before you cut to length ;-).
View bigblockyeti's profile
bigblockyeti
6341 posts in 2392 days
#15 posted 02-17-2020 03:09 PM
Just run them through one at a time, what’s the worst that could happen?
showing 1 through 15 of 31 replies
