Craftsman 113 table saw Arbor Sub Assembly is loose after bearing replacement.
Forum topic by RC84 posted 02-16-2020 03:59 PM 309 views 0 times favorited 3 replies Add to Favorites Watch
View RC84's profile
RC84
2 posts in 42 days
02-16-2020 03:59 PM
Hey guys -
I recently removed the arbor sub assembly housing to replace some worn bearings, on my craftsman 113 table saw.
Removal of the housing was simple as I removed the c clip and long washer. Took a little persistence to remove it from the shaft but nothing too bad.
After getting everything back together, I noticed the arbor housing shifted side to side…about .0625” +/-.
I tapped the rod that the arbor housing slides onto, so that the c clip sat more flush…thought that fixed it, but that was a temp fix. I ran the saw a couple times and now the looseness is back. Is there a something I’m missing in regards to reinstalling the arbor housing?
To be clear, there is no play in the arbor shaft itself as everything is very snug with the new bearings. This issue is regarding the shaft that the arbor housing install onto the trunion.
Any help or feedback would be much appreciated.
Thanks in advance.
3 replies so far
View Phil32's profile
Phil32
969 posts in 575 days
#1 posted 02-17-2020 08:37 PM
Could there have been shims on that arbor shaft that were placed during its initial alignment? Is it possible that you missed them when you removed the sub assembly?
JMG (just my guess)
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View MrUnix's profile
MrUnix
7809 posts in 2870 days
#2 posted 02-17-2020 09:06 PM
Emerson made a bunch of saws for Sears over the years… so you kind of need to be a bit more specific as to which one you have.
View RC84's profile
RC84
2 posts in 42 days
#3 posted 02-18-2020 04:02 AM
- MrUnix
My apologies, I assumed the arbor / trunion assembly was the same on sll 113s, other than the tilt being on the left side on older units.
For clarification, It is the 113.298032.
Regarding shims…I do not recollect there being anything besides the washer and clip.
At this point, I’m considering drilling and tapping the trunnion to lock the shaft down w a set screw.
