Maple crotch plate
« back to Woodturning forum
Forum topic by Karda posted 02-15-2020 06:24 PM 434 views 0 times favorited 6 replies Add to Favorites Watch
View Karda's profile (online now)
Karda
2070 posts in 1230 days
02-15-2020 06:24 PM
Hi I just turned a piece of maple crotch into a small plate. This is the first time using Jerrys chuck plate and steady rest, they work great never removed a tenon as cleanly. Also with the chick plate I no longer need to make a flat spot form a face plate. I have posted some pics of the process Thanks Mike
ready to turn
ready to remove tenon
tenon removed
bottom sanded and finished
View Nubsnstubs's profile
Nubsnstubs
1683 posts in 2407 days
#1 posted 02-16-2020 11:39 AM
Not to shabby at all, Mike. The next one you do, decorate it with a couple beads…........ Jerry (in Tucson)
Karda
#2 posted 02-16-2020 04:58 PM
thats asking a lot, I still have to learn to turn a thinner bottom
Nubsnstubs
#3 posted 02-19-2020 02:15 PM
Looks like since you found the solution to making better turnings, no one’s interested….... You need to go back to having issues….......... Jerry (in Tucson)
Karda
#4 posted 02-19-2020 05:36 PM
yea I can screw up that won’t be a problem. i have issues with this i have a hard time not leaving the bottom to thick
View OiBowyer's profile
OiBowyer
24 posts in 669 days
#5 posted 02-26-2020 09:42 PM
Hey Mike
I remember some of your earlier turnings and you’ve come a long way! You should be really proud of that.
As for your think bottoms (giggity). Have you tried running one hand down the inside and one down the outside at the same time. If your hands start to separate the bowl is to thick there. Make another shaping pass on just that part. You’ll get a better feel for it over time.
If you want a more technical and expensive solution. There is a digital caliper that measured the wall thickness. It works pretty well
-- Matt Bielenberg- turning student https://www.etsy.com/shop/Turning4SchoolMoney?ref=search_shop_redirect https://www.facebook.com/Turning-4-School-Money-213112446187330/?modal=admin_todo_tour
Karda
#6 posted 02-26-2020 09:55 PM
Thanks for the encouragement thanks for the tip. That will help. I am a no thech kinda guy so technical isn’t the best. I have a pair of bowl caliper, the non digital kind. They are a great help when I remember to use them. I’ll try the hand method when I go to turn thanks Mike
