Making table legs
Forum topic by MrRon posted 02-13-2020 04:42 PM 194 views 0 times favorited 2 replies Add to Favorites Watch
View MrRon's profile
MrRon
5831 posts in 3884 days
02-13-2020 04:42 PM
Topic tags/keywords: tip
A 3 legged chair, table, etc is much more stable than anything with 4 or more legs. There are leg adjusters that are used to level a table, and they are usually put on each leg. That is not necessary. Just cut one leg a bit shorter than the other three and put an adjuster on just that one leg. The other three legs will seek their own level and the leg with the adjuster will correct the level.
2 replies so far
View bilyo's profile
bilyo
1000 posts in 1743 days
#1 posted 02-14-2020 03:42 AM
Just because a 3 legged table is stable on an uneven surface doesn’t mean it is level. If you need it to sit level on a non-level surface, you will need to adjust more than one leg.
MrRon
#2 posted 02-15-2020 12:12 AM
By lever, I mean “reasonably level”, not perfectly level.
