Lathe Placement in Your Shop
« back to Woodturning forum
Forum topic by Steinbierz posted 02-12-2020 02:02 PM 1614 views 1 time favorited 51 replies Add to Favorites Watch
View Steinbierz's profile
Steinbierz
146 posts in 1147 days
02-12-2020 02:02 PM
Hello,
I am currently working on setting up my shop and was wondering what different ways folks position their lathes. I have seen many pictures showing the lathe against a wall and, in most of the pictures, lathe tools hanging on the wall behind the lathe. Other pictures show the lathe a little more out in the room with a bench or full tool board behind the lathe. I am lucky that I have the room to go either route but wouldn’t mind hearing from folks about their workflow, access to tools/chucks, etc. I am new to wood turning so I have not yet developed my own workflow but would appreciate any thoughts from more seasoned turners. Thanks.
-- Larry ~ Alvin, TX (Home of Nolan Ryan)
51 replies so far
View Nubsnstubs's profile
Nubsnstubs
1768 posts in 2740 days
#1 posted 02-12-2020 02:43 PM
One thing I found is never put a lathe lined up with a window. It’s not just to keep from breaking windows. The light coming in causes vision problems for me, and I’m sure I’m not the only one. .
Put you lathe away from a wall. It will allow you to get a better cleanup, and if you drop something, you can get behind the lathe to retrieve it. It will also allow you to put in a dust collection hood if you go that route. You might also want to turn from the opposite side of the lathe if you don’t have reverse. That would be only for hard to get areas inside of closed forms. ........... Jerry (in Tucson)
View pottz's profile (online now)
pottz
14862 posts in 1995 days
#2 posted 02-12-2020 03:01 PM
id say jerry has it right,i have a midi lathe on a bench against the wall but if i had a full size lathe id do what jerry said.
View MrUnix's profile
MrUnix
8422 posts in 3209 days
#3 posted 02-12-2020 03:09 PM
I have one against a cedar covered wall on the front patio, one against the wall with a sliding glass door behind it (with cardboard between) on the back patio, one on a Black and Decker Workmate in the workshop that can be moved where needed, and another that is sitting on the return of a Steelcase metal desk in a spare room. I put them where I can, and space dictates those locations :)
View ibewjon's profile
ibewjon
2269 posts in 3803 days
#4 posted 02-12-2020 03:24 PM
My powermatic 90 is a large machine, so I tucked it into a corner, enough room on the right to remove the tailstock, and a foot off the wall behind it. The left is clear for outboard turning if I get that far, and a knock out bar. Tools on the walk behind and on the right end wall. Just enough room behind for dust collection.
View poopiekat's profile
poopiekat
4898 posts in 4745 days
#5 posted 02-12-2020 04:21 PM
Keeping your lathe tools on the wall behind your lathe is NOT such a good idea. You don’t want to reach over a spinning workpiece to grab a tool.
View jmartel's profile
jmartel
9159 posts in 3160 days
#6 posted 02-12-2020 04:26 PM
Mine is up against a wall, but I don’t really have the room for any other way at the moment. My tools are stored on the lathe or realistically I put them on my assembly table behind me. I have a drawer in the assembly table dedicated to chucks/other lathe accessories.
Steinbierz
#7 posted 02-12-2020 04:55 PM
One thing I found is never put a lathe lined up with a window. It s not just to keep from breaking windows. The light coming in causes vision problems for me, and I m sure I m not the only one. .
Put you lathe away from a wall. It will allow you to get a better cleanup, and if you drop something, you can get behind the lathe to retrieve it. It will also allow you to put in a dust collection hood if you go that route. You might also want to turn from the opposite side of the lathe if you don t have reverse. That would be only for hard to get areas inside of closed forms. ........... Jerry (in Tucson)
- Nubsnstubs
Jerry,
Thanks for the reply; what you say makes sense. Thinking about it some more, I hate to take up wall space that could be used for hanging tools, maybe shelves for tools, bowl blanks, etc. so will probably plan on having it away from the wall.
Steinbierz
#8 posted 02-12-2020 05:00 PM
Keeping your lathe tools on the wall behind your lathe is NOT such a good idea. You don t want to reach over a spinning workpiece to grab a tool.
- poopiekat
Very valid comment but I hope that I would show better judgment than that…my wife might say otherwise though!
View controlfreak's profile
controlfreak
1782 posts in 612 days
#9 posted 02-12-2020 05:07 PM
This was my first thought too. I would see disaster coming if someone were reach over with a shirt tail or apron coming in contact with …..
View TheDane's profile
TheDane
5940 posts in 4673 days
#10 posted 02-12-2020 05:43 PM
My lathe sits smack-dab in the middle of the shop with a tool cabinet next to it. I access to both sides, and can turn off the end of the lathe just by moving the rolling Husky cabinet.
FWIW, I wouldn’t consider putting it against a wall with the tools on the wall behind it … too much risk of clothing getting caught while reaching for a tool with the lathe running.
View mike02719's profile
mike02719
293 posts in 4796 days
#11 posted 02-12-2020 05:53 PM
I find myself in disagreement with a previous reply in that says keep the lathe away from a window. Mine was against a wall and I moved it in front of window to take advantage of the light. When near the wall, I never could get enough light on the turning. Turning in front of the window, natural light not only is better, it raises my spirit and I enjoy turning more. I have had many items fly off, none came near the window. Against the wall, I installed shelves for turning related items not needed while turning. Way off to the right, is tool storage away from spinning blanks. On the top shelf in back of the lathe, is my dust/shaving collection devices. Underneath the full size lathe, is a trash can which catches a tremendous amount of shavings that I do not have to pick up. Next to the trash can is the shop vac, my best friend, ready to collect dust/shavings or do a thorough clean up. There on the nearby walls are HF magnetic strips for small metal items frequently used. Sorry to be so long winded, once I got started, I could not stop. Like drinking beer and eating pretzels.
-- Mike, Massachusetts
View PBWilson1970's profile
PBWilson1970
185 posts in 404 days
#12 posted 02-12-2020 05:55 PM
I was just wondering about this same situation as I am in the middle of moving my shop from the garage to a finished basement room.
Due to space limitations, against the wall seems like the best idea without overcrowding the shop space. I’m not a full-time turner so it really doesn’t warrant being in the spotlight.
I was thinking about storing my tools in the area towards the tailstock and not directly behind the lathe. I imagine it would get buried in shavings really quickly. With a bare wall behind the lathe, the chips will most likely hit it and fall to the floor where they can be swept and sucked up pretty easily.
The only thing I might add to the wall is an adjustable light and a fitting so that I can attach my dust collection hose to grab a bunch of sanding dust.
-- I love the smell of sawdust in the morning.
ibewjon
#13 posted 02-12-2020 06:51 PM
I am not turning spindles, so there is nothing to reach over to access tools. That end of the lathe is not used.
Steinbierz
#14 posted 02-12-2020 06:57 PM
Another issue for me to consider is how to get power and DC to the lathe if in the middle of the floor. I am assuming that doing a drop from the ceiling (unistrut or similar) would work on the headstock side of the lathe. I know drops vs. extension cords on the floor have been debated often and I tend to fall in the ceiling drop camp.
View GaryCK's profile
GaryCK
117 posts in 1059 days
#15 posted 02-13-2020 03:08 AM
I bought my first (benchtop midi) lathe last fall on a Black Friday deal and built a mobile workbench to hold it. It has room for the lathe on one side and the slow speed grinder for sharpening on the other. There are two wide drawers, one that holds lathe chisels and the other that holds mostly pen turning supplies, which has been most of my lathe work so far. The larger bottom cabinet space holds my face shield and some other larger supplies. The Oneway Wolverine sharpening jig slides next to or under the lathe when the bench is stored so it doesn’t stick so far out of the back as to be a pain.
This obviously doesn’t work well for a larger lathe and admittedly I’ve not turned anything that was incredibly off-balance to start with, so vibration may be an issue with the wheels in extreme cases, but they’ve held the bench very stable when locked with everything I’ve done so far. I’ve been quite pleased with how well it turned out and how useful it has been.
-- Gary, Wisconsin
showing 1 through 15 of 51 replies
