Has anyone actually tried or seen A DIY smart Saw operate
« back to CNC Woodworking forum
Forum topic by TDW posted 02-11-2020 04:15 PM 619 views 0 times favorited 3 replies Add to Favorites Watch
View TDW's profile
TDW
54 posts in 3763 days
02-11-2020 04:15 PM
This looks really interesting and I think I might be able to build it. What I worry about is designing a proram that tells the machine what cuts to make. I’ve tried to use CAD before and got lost.
-- Tom, Ky.
3 replies so far
View Bill_Steele's profile
Bill_Steele
708 posts in 2510 days
#1 posted 02-11-2020 08:01 PM
Are you referring to a CNC saw or the technology in a SawStop saw? Here’s an interesting video of a CNC saw used in architectural stone cutting.
View Madmark2's profile
Madmark2
1385 posts in 1367 days
#2 posted 02-11-2020 08:29 PM
AutoCAD generates .DXF files that can be used to generate the gcode that the CNC runs on.
There are other suites that are less “roll your own”.
-- The hump with the stump and the pump!
View Lazyman's profile
Lazyman
5469 posts in 2166 days
#3 posted 02-11-2020 09:47 PM
If you are talking about this, it is just a CNC router machine. There are many DIY CNC machines options out there. Here is a blog about it from last year for building the one Woodsmith magazine that might give you an idea what you are up against if you decide to make your own.
If the reason for you to build one is just for the fun of the build, I say find a good plan and go for it. If you have something specific in mind and since you are having trouble using CAD software, I personally think that you need to come up that learning curve first. The project will involve woodworking, sometimes some minor metal work, electronics and software just for the build. After that you need to be able to design on the computer unless your goal is simply to purchase designs that others have already made. Even then, you have to use software to prepare the design for you your machine. There is a fairly steep learning curve even using a turnkey machine and building a machine from scratch increases that significantly.
