Lexon or plexi-glass for picture frames ???
Forum topic by mel52 posted 02-05-2020 12:45 AM 493 views 0 times favorited 23 replies Add to Favorites Watch
View mel52's profile
mel52
1293 posts in 942 days
02-05-2020 12:45 AM
Topic tags/keywords: question tip tablesaw joining finishing arts and crafts modern
Hey there. I am in the process of making a few picture frames and would like to use something other then glass for them. Our local hardware store has 1/8 inch Lexon type plastic in stock. Would this thickness be enough for these projects ? Right now the sizes are 8 X 10 that I will be making. All info will be greatly appreciated. Thanks, Mike
-- MEL, Kansas
23 replies so far
View jopo's profile
jopo
49 posts in 1913 days
#1 posted 02-05-2020 12:52 AM
I’ve used the same before and liked it although I suspect they may yellow with UV exposure over time. The thickness is fine. If you are making your own frames, just add that amount into your rabbet depth calculations.
View LeeRoyMan's profile
LeeRoyMan
772 posts in 404 days
#2 posted 02-05-2020 01:10 AM
There is no reason to use lexan, or 1/8” thick.
I would find acrylic made for pictures with the non-glare surface.
The same site below also has the non-glare with the UV protection if you prefer it.
https://www.framedestination.com/framing-supplies/glass-and-acrylic/non-glare-acrylic.html
I’ve never used this site, just googled it to show the non glare option.
View robscastle's profile
robscastle
6798 posts in 2881 days
#3 posted 02-05-2020 01:51 AM
One of my many projects have been completed using Leaxn.
Here is the latesthttp://.
-- Regards Rob
View Joe Lyddon's profile
Joe Lyddon
10914 posts in 4730 days
#4 posted 02-05-2020 02:18 AM
I saw similar comments directed to an expert Frame builder…
He said “Glass”! (emphatically)
Reason: “Plastic, etc. etc. Always seem to scratch very easily when cleaning… I will never use it again.”
Glass will NOT scratch like Plastic, etc.
Just what I saw…
INHO, don’t play around… use the best, GLASS, all the way.
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php?media/albums/users/joe-lyddon.1389/
mel52
#5 posted 02-05-2020 05:28 AM
Thanks everyone for the replys so far. Mel
-- MEL, Kansas
View Andybb's profile (online now)
Andybb
2623 posts in 1281 days
#6 posted 02-05-2020 05:50 AM
I ve never used this site, just googled it to show the non glare option.
- LeeRoyMan
+1 That’s what retail frame shops use.
-- Andy - Seattle USA
View LittleBlackDuck's profile
LittleBlackDuck
3843 posts in 1498 days
#7 posted 02-05-2020 06:49 AM
Call me an ignoramus as I always thought that all those plastic “glasses” were the same… All I know is it’s not glass.
OK, just had a 30 second education by looking at the labels on my stock… over the last 10 years I never read the propaganda on the covering paper and always referred to it as plastic.
I have stockpiles of,
  1. Acrylic sheets.
  2. Plexiglass.
No idea where Lexon fits, but I can at least comment on the above 2 which I have found interchangeable in my use.
I used it to make a cover for my old man’s bread sculpture. I found it was a breeze to laser cut and when I had to bevel it, found it was tablesaw friendly. The one thing over glass is that you can take off shaving and shape, bend with heat and bounce of the floor without the resultant wade in blood.
Furthermore, if you cock it up, you can easily resurect it.
View doubleDD's profile
doubleDD
9198 posts in 2720 days
#8 posted 02-05-2020 02:01 PM
In the long run you will be happier if you use the glass. There’s no comparison. You will start loosing clarity after a while with anything other than glass. Just my 2 cents.
View Don Newton's profile
Don Newton
727 posts in 4296 days
#9 posted 02-05-2020 04:28 PM
Plastic has static electricity that will attract every piece of dust in the house. Use glass, it’s cheaper.
-- Don, Pittsburgh
View Brawler's profile
Brawler
134 posts in 508 days
#10 posted 02-05-2020 05:13 PM
Call me an ignoramus as I always thought that all those plastic “glasses” were the same… All I know is it s not glass.
  1. Acrylic sheets.
  2. Plexiglass.
I used it to make a cover for my old man s bread sculpture. I found it was a breeze to laser cut and when I had to bevel it, found it was tablesaw friendly. The one thing over glass is that you can take off shaving and shape, bend with heat and bounce of the floor without the resultant wade in blood.
- LittleBlackDuck
Lexan is polycarbonate, almost unbreakable and easy to shape with heat. Acrylic is Plexiglas, much more brittle than polycarbonate.
-- Daniel, Pontiac, MI
robscastle
#11 posted 02-05-2020 07:15 PM
And now considering the flammable characteristics polycarbonate will not sustain fire whereas other plastics will.
A consideration in electronics where guards are used and there is a risk of fire i.e. hi voltage equipment etc.
-- Regards Rob
robscastle
#12 posted 02-05-2020 07:17 PM
Just add this to the other useless trivia Idribble
-- Regards Rob
View Fiver's profile
Fiver
76 posts in 79 days
#13 posted 02-05-2020 07:32 PM
So I’ll just say upfront that my feedback is based on growing up with a father who made his living as a professional photographer.
Since you’re ultimately looking to use something for a picture frame, I too would recommend glass…unless there are other considerations such as being concerned about UV impacts on the photo over time or something wherein you might want to look at other options. If this is just for a photo frame, go with glass.
-- Matt - Colorado
View them700project's profile
them700project
235 posts in 1696 days
#14 posted 02-05-2020 09:24 PM
when I bought my first this past summer I found if you wanted UV/anti glare you could get 5 pieces of acrylic for the price of the same in glass.
11×14 I got 5 for 46. Glass is 47 by itself from frame destination. I agree glass would have been better but My frame was only OK in quality so I wasnt too worried.
LittleBlackDuck
#15 posted 02-06-2020 12:15 AM
- Brawler
Thanks for the lesson Brawler... If only I could have avoided that dreaded reading of your feedback (I hate reading)... so now I stand as an ’amus (with an ”m’... only half an ignoramus).
So I ll just say upfront that my feedback is based on growing up with a father who made his living as a professional photographer.
- Fiver
I retract my 0.02c worth for the Fiver. For straight square cuts without the need to shape… you can’t beat glass (without breaking it).
