Suggestions for tile replacement
Forum topic by dschlic1 posted 02-04-2020 06:14 PM 417 views 0 times favorited 10 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
515 posts in 3261 days
02-04-2020 06:14 PM
Topic tags/keywords: question
I don’t know if this is the correct place or even the correct website for my question. We recently had a whirlpool bath tub installed in our master bath. The surround and deck is covered in ceramic white tile about 4” square. The issue I am concerned about is the service access hatch for the whirlpool. The installer was going to cover a cement board with the white tile and screw it to the surround framework. However they had problems with the screws cracking the tile. Instead they placed the hatch and used some bullnose trim tiles to hold it into place. To gain access these trim tile will need to be removed and then replaced.
My though is to try and find an acrylic sheet with a white tile pattern. However I can’t find any. Does anyone know of a source for such an item? Also any suggestions other than using an acrylic sheet?
10 replies so far
View Kazooman's profile
Kazooman
1540 posts in 3243 days
#1 posted 02-04-2020 06:39 PM
There are many ways the tiled cement board could be held in place other than running screws through it (bad idea from the get-go and wouldn’t look very good). How about magnets?
View bold1's profile
bold1
362 posts in 3138 days
#2 posted 02-04-2020 06:42 PM
Can’t help you with the acrylic sheet, but I have seen the access hatch attached at the top with a strip of stainless piano hinge and just the weight of the tile holds the hatch shut. I would say that if you would want to you could even hold a pretty good size hatch in place with several super magnets. Some on the surround and some on the hatch.
View LesB's profile
LesB
3146 posts in 4734 days
#3 posted 02-04-2020 11:38 PM
Half inch rare earth magnets will hold if they are paired up at at least 4 places on the hatchs perimiter. Pair them with one in the door and one on the hatch frame….make sure you get the polarity matched before you blue them in. To make it even stronger get the mounting cups that hole them.
-- Les B, Oregon
View pottz's profile (online now)
pottz
21412 posts in 2275 days
#4 posted 02-04-2020 11:55 PM
if you have question specifically about home improvement try home refurbers it’a a sister forum to lumber jocks you can use your same sign on.its all about home remodeling and construction.
dschlic1
#5 posted 02-05-2020 05:24 PM
Magnets are a possibility but how can I create a pocket in the cement board for the magnets to fit into?
View Madmark2's profile
Madmark2
3178 posts in 1879 days
#6 posted 02-05-2020 05:41 PM
With a masonry bit in your drill
-- The hump with the stump and the pump!
Kazooman
#7 posted 02-05-2020 05:50 PM
- dschlic1
If you can’t drill into the board you could explore surface mounting magnets on the board and have the magnets they will interact with recessed in the wooden frame the correct depth.
View robscastle's profile
robscastle
8299 posts in 3495 days
#8 posted 02-05-2020 08:28 PM
Pottz is on the button
And as a result I have flagged for consideration for relocation to the correct area.
-- Regards Rob
pottz
#9 posted 02-05-2020 08:47 PM
- robscastle
easy buddy it was only a suggestion ;-)
robscastle
#10 posted 02-05-2020 10:42 PM
No probs you suggested, and I acted, its up to the mediators now Over and Out Buzzzit
-- Regards Rob
