Attaching metal pipe to wood - what type of fittings are these?
Forum topic by Theregoesplanb posted 01-25-2020 11:37 PM 305 views 0 times favorited 1 reply Add to Favorites Watch
View Theregoesplanb's profile
Theregoesplanb
1 post in 30 days
01-25-2020 11:37 PM
I’m attaching a few pictures of a shoe rack that we’re currently using. I’d like to build something very similar to this, but make it a bit taller and replace the telescoping rods with straight pipe. I’d like to use the same style of fittings that the current piece uses. I’m attaching a couple pictures that illustrates what they look like. Essentially there’s a male stud that screws into the side of the shoe rack and there is a piece of rubber/nylon inside the pipe that creates a tension fit when slid over the stud.
I’ve been searching all over trying to find similar fittings. I can’t reuse the existing fittings because I need 4 more and the current pipe is 1/2” ID, which I can’t seem to find anywhere as well (just 1/2” OD). Anyone know where I can find similar fittings and finished pipe to match?
Shoe Rack: https://imgur.com/Kg7HHN8
Fitting System: https://imgur.com/b4oCQTc
Stud Fitting: https://imgur.com/O40MiBB
1 reply so far
View Walker's profile
Walker
231 posts in 1109 days
#1 posted 01-26-2020 03:52 AM
If you’re replacing the pipe and fittings anyway, then why not just use something commonly available at the hardware store. Like 1/2” black steel pipe and corresponding floor flange.
-- ~Walker
