Wen 10 in bandsaw or Rikon 10 in deluxe bandsaw?
Forum topic by Coleman Dodds posted 01-22-2020 05:49 AM 1507 views 0 times favorited 8 replies Add to Favorites Watch
View Coleman Dodds's profile
Coleman Dodds
24 posts in 765 days
01-22-2020 05:49 AM
Topic tags/keywords: bandsaw wen rikon 10 in bandsaw
So I’ve been debating whether to get the Wen 10 in bandsaw or the Rikon 10 in deluxe bandsaw. I’ve done research on both. I’ve seen from multiple sources that the Wen is a good machine for the money, but it is hard to set up and also needs adjusted a lot. I’ve also seen that the Rikon is a very good and a quality machine, but it is also near $200 more. I have the money for either but wanted some input.
Thanks
Coleman
8 replies so far
View SMP's profile
SMP
4823 posts in 1147 days
#1 posted 01-22-2020 05:56 AM
I would personally get the Rikon. But check if there are any Sears stores anywhere near you as they are closing out inventory and I think its about the same price.
View EarlS's profile
EarlS
4752 posts in 3590 days
#2 posted 01-22-2020 01:15 PM
Rikon – the WEN is not even in the same league. I bought the WEN thinking I could save some $$. Now I have a low quality Chinese bandsaw that I will have to sell at a loss and still buy the Rikon. The Rikon is worth the extra $$.
woodbutcherbynight
10396 posts in 3651 days
#3 posted 01-22-2020 01:52 PM
Thanks
Coleman
- Coleman Dodds
Rikon came out with the 10-306 Bandsaw early last year. Starting price was $375. It knocked down the 10-305 prices and I got mine at $250. Having seen a WEN and a Rikon, buy the Rikon, even the older model. Very nice machine for this size and has worked well since Jan 2019. It may be small but has handled all the odd jobs I have thrown at it. For larger work I use a JET 14 inch.
View YesHaveSome's profile
YesHaveSome
189 posts in 1500 days
#4 posted 01-22-2020 03:20 PM
I have the WEN and it’s okay. The blade that comes on it is complete trash to the point where I avoided using the saw. I then bought a 1/2” woodslicer from Highland Woodworking and the saw works great. I upgraded to a Laguna 18bx last year and figured I’d give away the WEN. Turns out it’s nice having a second bandsaw so I’ve kept it. I can’t compare it to the Rikon though but I suspect the Rikon is a better saw. I believe you generally get what you pay for.
-- But where does the meat go?
View torus's profile
torus
545 posts in 1655 days
#5 posted 01-22-2020 03:48 PM
I am very happy with Rikon 10-306. The only negative – carter stabilizer for 10-305 does not fit it.
-- "It's getting better..." - put this on my RIP stone!
View Davevand's profile
Davevand
288 posts in 2078 days
#6 posted 01-22-2020 04:08 PM
Rikon updated the 10-306 to the 10-3061 ti fix a few of the issues it had. nothing serious IMO. The Rikon is the saw to buy
View RJweb's profile
RJweb
147 posts in 3874 days
#7 posted 01-23-2020 03:38 AM
Rikon should be having their 15% off coming up very soon, RJ
-- Life Begins @ 190 MPH
View Karda's profile
Karda
3376 posts in 1795 days
#8 posted 01-23-2020 04:04 AM
I have the en 10”, it a good saw if you use 3/8th blades, I can’t get it to adjust to a .5” blade as well as the 3/8ths. I f i had to do it agin I would get a 14” 72” blades are hard to find some times. Also the upper guides can’t be adjusted individualy, they work like a caliper brake, one moves the other. It could have more power
