Saw Blade ID
Forum topic by Adamal posted 01-20-2020 07:59 PM 202 views 0 times favorited 4 replies Add to Favorites Watch
View Adamal's profile
Adamal
61 posts in 2631 days
01-20-2020 07:59 PM
Hi folks. I’ve got an old 10” Delta blade that I got from work years ago and I’m trying to figure out what is best use is. It was sitting around for a good 25 years before I grabbed it. It’s great shape and very sharp.
Anyway, it’s a Delta 35-625, 80 tooth with a negative rake. When would I want to use this instead of my trusty Tenryu Gold Medal? It’s not your normal crosscut blade.
I’ll give pic for the heck of it.
Thanks.
View knotscott's profile
knotscott
8365 posts in 4006 days
#1 posted 01-20-2020 08:56 PM
Should be great in a RAS, slider, or miter saw if you have one, but should also do well in sheetgoods, and fine crosscuts on a TS. Test it and see!
View Andybb's profile
Andybb
2486 posts in 1234 days
#2 posted 01-20-2020 09:21 PM
- knotscott
+1 The 80 teeth make it good for non-tearout on sheet goods like plywood and smooth cuts on a miter and radial arm saw.
-- Andy - Seattle USA
View therealSteveN's profile
therealSteveN
4857 posts in 1205 days
#3 posted 01-20-2020 09:50 PM
What kind of work was it?
I did a search for 35-625, and the hit below said it was this on Goofle images, but following the link to FleaBay it morphed into the Delta 35-624, close but no stogie.
The description says, it is suggested “For cutting brittle and hard abrasive type materials when a finish cut is desired.” Sounds a lot like OSB or maybe even tile backer board. Definitely would make it a specialty blade, when compared to the norm.
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=184126594946&category=122838&pm=1&ds=0&t=1579543287000&ver=0
-- Think safe, be safe
Adamal
#4 posted 01-20-2020 11:35 PM
That funny. I’ve got the 35-624 also from the same place. I wasn’t too curious about it because it looks like a plain old crosscut blade.
- therealSteveN
It’s funny. I have the 35-624 too. I got it from the same place, at the same time. I never thought much about it because it was just a nice crosscut blade to me. It’s the negative rake on the other one that had me wondering.
Thanks!
