Posting this to save others a headache, especially if you are in Canada where Schedule 20 is rare apparently (at least in GTA)
I was trying to implement this
but in my case the black piece used to connect the hose which he is pushing into the white one was lose.
He is using a connector from Iron pipe to 4" PCV pipe. It has the advantage of having a sholder that helps the reducer to sit well on the lid.
Instead of using that I used a coupler (4") and a corrugated garden pipe to PVC pipe adapter
Prices are in CAD. If I get it done tomorrow I might post pictures. Most of the work is done , I need to glue or silicon it and cut one more 4" piece that will lower the 90D elbow in a better position
