Forum topic by Travis | posted 01-18-2020 08:52 PM | 747 views | 0 times favorited | 16 replies | ![]() |
Hi all, I am working on the base for a trestle table. First time building a table, and first time doing M&T joinery. I’m trying to make sure my fit is solid between legs and feet before I start the legs to cleats. Try as I might, I cannot get a tighter fit than this. Is this typical, something to just fill in with a dab of filler? I tried shaving off just a hair on the inside of the tenon to encourage the outside to sit perfectly flush. It doesn’t seem to have helped all that much. I’ve double checked that my depth is okay. I’m not sure how much energy to put into tweaking this, especially since I think I’m as likely to make things worse the more I fiddle with it. I doubt anyone will see unless they get eye level with the floor. What do you think? What would you do? -- The plan is wrong; my finished piece is right. |
16 replies so far
#1 posted 01-18-2020 09:21 PM |
Hi Travis, I’m by no means an expert, but I’ve often found that happens to me when I haven’t cut the shoulder perfectly square to the face. That causes the part of the shoulder closest to the tenon to be every so slightly longer than the portion closest to the face of the board, and it gaps a little. I usually just bevel the shoulders in just a tad with a chisel and it sits tighter. Not positive that’s what’s happening, but just a thought. Perhaps that’s what you meant when you said you shaved a little off the inside of the tenon. I also usually pin mine, which tightens it up considerably. That being said, those look great, and as you say, I’d bet no one would ever notice that small of a gap under a table. |
#2 posted 01-18-2020 09:34 PM |
Travis, It’s certainly possible to get a completely tight M&T joint. Looking at your pics, it looks like the gap is all the way around, so there’s just a few things to check. 1. Make sure the mortise is deep enough for the tenon everywhere. It’s not uncommon to have a mortise bottom that is not perfectly level and even a couple of mm in a tight mortise could cause this. Check the depth in a bunch of places. Taking a little off the tenon length won’t impact the joint strength. 2. The shoulder of your tenon is not really square and level. Use a combination square and double check everthing. 3. Hit it harder. Sometimes in a nice tight mortise, the difference between a beautiful almost invisible seam and a gap is just how much force you use to close it up. If none of those help, then you have three choices: Mike -- No honey, that's not new, I've had that forever...... |
#3 posted 01-18-2020 09:36 PM |
Also would mention the scab method is also how you cure a tenon that is cut too thin or a mortise cut too wide. You cut a piece and glue it long grain to long grain to the side of the tenon and then cut the tenon to thickness again. -- No honey, that's not new, I've had that forever...... |
#4 posted 01-18-2020 09:52 PM |
+1 What they said. One step at a a time. You are only an adjustment or two away. Nice work for your first try. After first making sure the tenon isn’t too long I’d make sure the shoulders are square. They look level so if the tenon isn’t too long then a little chisel work at the base of the tenon should do the job. 90 % sure that’s your problem. As long as there is glue in the joint you can also rub it with fine sawdust from the same wood. Or forget it. -- Andy - Seattle USA |
#5 posted 01-18-2020 10:04 PM |
Thanks chuk, Yes, that’s what I meant—should have said I shaved a little off the inside shoulder, not the tenon ;) When I shaved off the shoulder I didn’t truly bevel, just took a little off the inside. So it may be that I didn’t bevel far enough out. I’ll give that another try. The way the gap goes around all 4 sides, I’m inclined to think that’s the problem (unless my mortise is too shallow, as Mike and Andy mention). -- The plan is wrong; my finished piece is right. |
#6 posted 01-18-2020 10:08 PM |
I like your recommendations for what to do if I can’t fix it. At the end of the day, it’s not a big deal :) -- The plan is wrong; my finished piece is right. |
#7 posted 01-18-2020 10:10 PM |
Thanks Andyb! I’ll take another whack at it. -- The plan is wrong; my finished piece is right. |
#8 posted 01-18-2020 10:11 PM |
Another thing on non-through M&T is I bevel all the edges on the end of the tenon. Sometimes there is just something in a corner keeping it from seating. Also helps with too much glue that gets trapped. Undercutting the shoulders just slightly, so only the show edges need to fit tight. And drawboring can also help pull it tighter. |
#9 posted 01-18-2020 10:19 PM |
I think I will drawbore, or at least pin, to give them some extra reinforcement (these are my first M&Ts, after all). I am a little concerned though that I will mess up the fit when I do that. -- The plan is wrong; my finished piece is right. |
#10 posted 01-18-2020 10:22 PM |
Yep. That too. 5 mins with a chisel and you’re good to go. Good work.
Yep. That also. I’d fix the fit and glue and clamp it well and be done. After it’s dry if you want to put a dowel through it, do that. -- Andy - Seattle USA |
#11 posted 01-19-2020 03:29 AM |
The shoulder of the tenon needs to be undercut slightly. This will improve the fit and strength. Good Luck -- Aj |
#12 posted 01-19-2020 02:06 PM |
AJ has a good point. If paper won’t work ten try a thin feeler gauge and see if you can get to the tenon all the way around (which means the mortise bottom needs work) or you’ll find the bit that is landing early feeling around. -- No honey, that's not new, I've had that forever...... |
#13 posted 01-20-2020 03:53 PM |
The undercut method is a classic way to get the tight joints. Looking at the photos. could the end of the tenon board be slightly rounded over? I wouldn’t use filler since it tends to flake out when used at joints. |
#14 posted 01-22-2020 02:22 AM |
I’m glad you brought that up because I was wondering that myself. I usually round all my edges but I assumed one normally kept those edges sharp. Do people generally round over those mating edges? Would it look weird if I did? -- The plan is wrong; my finished piece is right. |
#15 posted 01-22-2020 03:59 AM |
Another method is to chamfer the edges of the visible end of the piece and let the gap show as uniform space. Takes your eye away from any imperfections…. |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2790 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6304 |
7862 |
32560 |
CNC Woodworking
325 |
Hand Tools
6430 |
Jigs & Fixtures
1788 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5397 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
